Ok thanks
Ok thanks
Pcm died anyway of recovering it or is it junk and how do i make sure it doesn't lock up my new one
I deleted the cax uninstalled efilive reloaded it put in a program that never had the cax in it am i safe now
As long as you flashed back in the tune file from before you modified it with the incorrect cax file, you should be fine.
The Tremor at AIR
I used the first one i uploaded here to make sure it was before i heard about the cax the car was running fine driving down the road and it just shut off and i can't get into the pcm i assume that the cax was the cause but i had already deleted it and loaded a different tune in it
DID YOU DO THIS:
full flash a good tune file (from before the cax)...?
I did that too before and loaded a tune without the cax but. It may have already done the damage
No i had a extra and bought another licence
