Results 1 to 4 of 4
Thread: LML EGR issue
    akaponch
    Guest
    Default LML EGR issue
    I'm working on deleting 2013 lml. I removed dpf and installed new pipe section. Got all that working and made a couple test runs. When I park, before turning truck off there is no MIL light. When I restart I get a MIL light P140F and P1407. I looked those up they are EGR related. I havent messed with EGR yet. I'm wondering why it keeps coming up.
    P1407=EGR motor control shorted
    p140f=EGR motor current performance
    Any ideas?
    akaponch
    Guest
    I haven't figured this one out. I blocked EGR and i still get those two. Can i just disable those two DTC reporting. I tried disabling those two and truck continues to operate ok without the MIL on. Should i leave it like that?
    Jul 2014
    How did you block the code? I think I have all the 2013 LML files and do not see any codes that can be blocked in the Engine Diagnostics section
    Jul 2014
    Nevermind, figured it out.
  1. LML will not open
    By panzerwillie in forum Duramax 2011+ LML / LGH
    Last Post: September 4th, 2014, 02:05 PM
  2. Wierd issue after flash, airbag light on & oil reset issue
    By Tool Guy in forum Gen III V8 Specific
    Last Post: October 1st, 2013, 06:55 PM
  3. Replies: 21
    Last Post: July 7th, 2013, 11:31 AM
