Results 1 to 10 of 10
Thread: Boss Hoss Tuning
    Feb 2014
    Default Boss Hoss Tuning
    Hello,
    Can the EFIlive tuning system hook into a Boss Hoss motor bike that runs LS engine?
    It has 4 wires to the datalogging/Scan tool plug but uses a non-standard OBD plug.
    I can get pictures of this plug if it helps.
    Regards,
    Brendan.
    May 2012
    what PCM or ECM does it uses? IF it is a GM compatible one, it should read/tune
    +1 engine controller has to be a GM GenIII PCM or GenIV ECM.
    Feb 2014
    Quote Originally Posted by 400ss View Post
    Will get the covers pulled off and find what ECM is in it.
    Would imagine they would use the GM one.
    Feb 2014
    Pulled the covers over and have Identified the ECM as a E67.
    Traced the 4 wire datalogging port back to ECU and here is the pin out.
    Wire 1, Orange = 12V
    Wire 2, Black = Earth
    Wire 3, White/red = CAN+
    Wire 4, White = CAN-
    Rest of places on plug = Blank.
    May 2012
    Quote Originally Posted by bmgjet View Post
    get an OBD2 connector and rewire it like this::
    Wire 1, Orange = 12V----------------------------- PIN 16 on OBD2 connector
    Wire 2, Black = Earth----------------------------- PIN 4 and 5 OBD2 connector
    Wire 3, White/red = CAN+ --------------------- PIN 6 OBD2 connector
    Wire 4, White = CAN- ------------------------ PIN 14 OBD2 connector
    Now you can read and tune it.
    Feb 2014
    Thanks for the reply. I have already made a cable up using a old network cord and cut one end off it then followed the.
    Bench Harness Tutorial.
    It detects the ECU as E67 and starts to read but about 40 secs in error pops up. "Received no data".
    So im going to go down to the wreackers and cut off a OBD2 plug and make a nice looking adapter then just using a pin headder on the end of a network cord.
    May 2012
    Perfect, have fun. let us know if it corrects the problem.
    Feb 2014
Name:	boss-hoss obd2 plug.jpg
    Cable adapter made, Just need to get the owner back with his bike and try it again.
    May 2012
    Nice adapter. Let us know the results
  1. Replies: 7
    Last Post: June 1st, 2012, 04:26 PM
  2. 08 Silverado 5.3 Tuning, tuning-spark/pe mode/
