Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 92
Thread: autove help please
    Jun 2014
    Joe;
    I did save the log/file....I'll post up the info in the morning.... (I have better internet at work). I'm not sure what model arm...its only 6 months old with the gage....I have the 5v+ and a ground hooked up to Adv1 input and set pids to plx .....its off but I've been adjusting my counts...I'm just trying to get the tune in the ballpark and learn....
    After I open the log file, no where can I find the page on the map to copy and paste to my ve....
    Jun 2014
    Quote Originally Posted by 400ss View Post
    First you select the pids right? Then you do the log. Then stop the log and save it. When looking on the map you did you can changue the to view cell count or average of the input data
    Yes, I've successfully logged and pasted to my he several times.....just my best log is corrupt and was hoping to recover it....
    Joe: I know its not afrs....I'm not sure what the 10's are from? I know I didn't follow the instructions and it happened....it happened a few times....no matter what I do while viewing the log, can I get the 0.8-1.2's to come back
    Lifetime Member johnv's Avatar
    Jan 2005
    I think you must have just opened the wrong Map, click on the MAP tab, then click on the A B C D E F G .... to display the different saved Maps,
    you want the Ben Map so you can paste and multiply in your VE table.
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
    Jun 2014
    No other maps made yet...when I try to copy and paste to my ve, they all read 500.....
    This happens after I save a log and reopen it....
    May 2012
    Copy with labels and paste and multiply with labels
    Quote Originally Posted by garyk1970 View Post
    What does the map look like (post screenshot)...?
    When you paste, do you paste-multiply...?
    Are you trying to follow the AutoVE tutorial...?
    If so, then there are a few things you need to address:
    - PE Enable needs to be edited to enable easier,
    - OL STFT trimming needs to be disabled (B4205),
    - log GM.EQIVRATIO instead of GM.AFR;
    also things will be easier if you do the following:
    - use EQR for fueling units (rather than AFR),
    - use g*K/kPa for VE units;
    To see examples of maps, look at post #1 of the Calc.MAFT thread... this is an updated AutoVE (ignore the part about calculating/pasting the MAF table)... you can tailor it to use only wideband.
    Post your calc_pids.txt file (from the User Configuration folder).
  9. #19
    Jun 2014
Name:	cell count.JPG
Name:	ve pasted.JPG
  10. #20
    Jun 2014
    ok...i think ive got it...
  1. Replies: 32
    Last Post: June 24th, 2010, 06:21 AM
  2. doing autoVE
    By nathans1987 in forum Gen III V8 Specific
    Last Post: May 3rd, 2009, 06:20 PM
  3. AutoVE with the RR
    By Whippled 496 in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 20th, 2008, 02:09 PM
  4. AutoVE with V2?
    By nonnieselman in forum Custom Operating Systems
    Last Post: March 24th, 2008, 07:50 PM
  5. AutoVE, What next?
    Last Post: April 11th, 2006, 08:45 AM
