Thread: Update: Feb 09, 2015
    Default Update: Feb 09, 2015
    Both the V7.5 and V8 software was updated in this release, you must update both software packages.
    Release Notes:
    Known Issues:
    Check for known issues here.
    IMPORTANT, please see Issue 5 in the known issues link above.
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the "known issues" thread above.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 277
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 271
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Firmware, Click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.78 (Feb 09, 2015
    To view/update the Boot Block, Click the [Check Firmware] button in the V8 Scan and Tune software.
    The EFILive Development Team
    Dec 2006
    Thank you
    2007 LBZ 2011 LML Silverado Pickups
    2015 GMC Denali 3500 Dually Diesel Pickup
    2007 Dodge 6.7 Pickup
    Thanks.
    Jun 2014
    Thanks again
    Oct 2005
    Does this fix the DMA PID issues in the E38 ECU that Andrew and I were experiencing?
    These showed as invalid and could not be BBL or Pass through logged..
    2014 VF SV LS3 Maloo.
    Quote Originally Posted by ringram View Post
    Yes.
  1. Update: Feb 2015
    Last Post: February 21st, 2015, 09:59 AM
  2. Known issues with Feb 09, 2015 release of the EFILive software and firmware.
    Last Post: February 12th, 2015, 08:04 AM
  3. Known issues with Feb 2015 release of the EFILive software and firmware.
    Last Post: February 9th, 2015, 11:53 AM
  4. Update: Jan 2015
    Last Post: February 4th, 2015, 06:55 PM
  5. 5.9L Beta update - Feb
    By GMPX in forum Cummins 5.9L
    Last Post: February 18th, 2011, 10:41 AM
