Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Can I convert to flex fuel?
    Feb 2014
    Can you look at my tune to see what im missing
    Senior Member JUSTASBC's Avatar
    Aug 2010
    Sure. Email it to me if you want. Dwrobb99@yahoo.com
    05 Joe Gibbs black RCSB ram air hood, Leer tonneau, blacked out tail and head lights. Forged 370, Eagle crank, Wiseco pistons, Compstar Rods, Pro Flo XT intake, KB Racing log, spool valve, T6 S480 1.32 A/R, boost activated cutout, TSP 2.5 5.3l heads, Comp Cam 224/230 .600 with rockers, comp cams 1.75 roller rockers, dual Walbro 450's, Injector Dynamics id1300's, 4l80e w/3200 multidisk Circle D, trutrac w/3.73's, 3"DI/DO Magnaflow, tips through the roll pan, running COS3 Semi OLSD OS#12592618
    Aug 2010
    Quote Originally Posted by JUSTASBC View Post
    ... I did a segment swap of an E85 version ...
    Nicely done - as you discovered the Flex Fuel version of the same OS is very different.
    Feb 2014
    So my pcm will read my sensor just need to do the swap?
    Aug 2010
    Quote Originally Posted by danny68ss View Post
    Your original tune was not a Flex Fuel variant - so you are missing the Flex Fuel parameters (all of them).
    Changing the Flex Fuel parameters visible in EFILive is not sufficient to enable Flex Fuel calculations on a non-Flex Fuel calibration.
    Feb 2014
    Ok just found a l59 with same os and did a segment swap engine calibrations is that what i needed
    Aug 2010
    That should work. I saw a flex fuel version for a Tahoe.
    Feb 2014
    Thats what i found too engine segment is what i need isn't it
  9. #19
    Feb 2014
    Thanks it works now
  10. #20
    Good job
  1. Flex Fuel for LS1
    By mr.prick in forum Custom Operating Systems
    Last Post: July 6th, 2014, 05:21 AM
  2. Flex Fuel problem?
    By 2007chevy5.3l in forum Gen IV V8 Specific
    Last Post: November 21st, 2011, 03:24 PM
  3. Convert 2000 F-Body OS to a Flex Fuel OS?
    By coctostan in forum General (Petrol, Gas, Ethanol)
    Last Post: September 23rd, 2009, 04:46 AM
  4. Flex fuel sensor
    By vzsv8 in forum Gen III V8 Specific
    Last Post: February 24th, 2009, 11:35 PM
  5. Converting a NON-Flex fuel vehicle to Flex fuel??
    By kbracing96 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2008, 06:15 AM
