Originally Posted by
GMC-2002-Dmax
If you have a script that is corrupted, and I do not know how it happens but it happened to me so I know what it is your experiencing.
Do not use that dead pedal file as a base file, or as a compared file or to make a script, if you did that the reason the dead pedal is there is because you used the same corrupt file or compared that corrupt file.
I bet if you redid the tune using the clean TIS and not a compare or script it would be fine.
I use TIS files or library files from my PC all the time, ni issues swapping between them.
