Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
Thread: Help with csp5 2800rpm fuel issue?
  1. #21
    Senior Member garrettg.bpd's Avatar
    Jun 2013
    If I remember correctly 50psi is 5 volts. If the pcm sees 5 volts it thanks there is a fault. All of your maps stop with less boost then your truck can produce. So where ever you boost exceeds the value in your tables the max value will be what use at the end of your run.
    EFILive Beta Tester
    2006 DODGE RAM 2500 4X4 Industrial Injection R1 100HP Injectors and BAG-O-PARTS, ATS Exhaust Manifold, AFE 67MM Turbo and MANIFOLD
  2. #22
    Jun 2013
    If you would like pm, email or post your tune and log so I can review it in the a.m.
    EFILive Beta Tester
  3. #23
    Sep 2014
    Can I get your email
  4. #24
    Jun 2013
    EFILive Beta Tester
  5. #25
    Sep 2014
    Quote Originally Posted by garrettg.bpd View Post
    Sent
  6. #26
    Nov 2015
    Bringing this back alive. I am having a similar issue. It slowly pulls command after each shift. I have all limiters turned off and re-scaled boost table. Scratching my head right now.
Name:	pulling fuel1.PNG
  7. #27
    Jun 2013
    What's your fuel pressure doing?
    EFILive Beta Tester
  8. #28
    Nov 2015
    Stays steady right at ~23k psi.
  9. #29
    Senior Member tylerltr450's Avatar
    Aug 2014
    Did you change your shifting for rpm and command?
    2006 Cummins Red, Auto to Nv5600, SBC 3600, Traction Bars, Visor, Running Lights, S&B Intake, ATS intake horn, EFI Live, Borg Warner S363 Turbo, Industrial Injection Dragon Fly Injectors.
  10. #30
    Nov 2015
    Quote Originally Posted by tylerltr450 View Post
    Yes I did some. It's like it's keeping main duration under 2000 so it pulls command.
  1. Issue with upgrading to CSP5 operating system...
    By LPDTuning in forum Cummins 5.9L
    Last Post: December 3rd, 2013, 04:09 PM
  2. Issue with CSP5 switching
    By saintb6969 in forum Cummins 5.9L
    Last Post: November 20th, 2013, 02:54 AM
  3. Strange fuel issue
    By Forcefedperformance in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 24th, 2009, 07:13 PM
  4. Fuel injection issue
    Last Post: June 2nd, 2008, 02:50 AM
  5. Fuel Issue
    By Beer99C5 in forum Gen III V8 Specific
    Last Post: May 19th, 2007, 11:08 AM
