post the cax file.. i'll fix the error.
Found my error. Per post #10 in the cax update thread, I placed it in the configuration file. Moved it to the calibration file and deleted my old cax thread and now it loads without the warning. Thanks.
2000 Formula: 12212156, bolt-ons, 3600 stall, 3.42's.
Apparently when you call something B8101 weird things happen. I took pixs.
cav.pdf
Yeah don't use....
B8101 to B8106
OR
B8151 to B8156
These are used by the Virtual VE tables in various ECM's.
In a cax you would use table id's in the range B9000 to B9999 to avoid colliding with any predefined tables id's.
752 of those are currently occupied by the mess that is the DTC table. I suppose I could make everything higher than B10000 (assuming there isn't anything in those ranges). I know the program will accept the values, but I'm not sure if they will cause other hidden issues by adding another digit.
