Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: Known issues with March 2015, Release Candidate 1
    Default Known issues with March 2015, Release Candidate 1
    Currently known issues and possible workarounds for the March 2015, Release Candidate 1 of the EFILive Software and Firmware
    • Software: V7.5.7.280
    • Software: V8.2.2.274
    • FlashScan/AutoCal firmware: V2.07.81
    Issue 1:
    Workaround:
    None. It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
    May 2008
    tuning an lly tonight and everytime I save the LLY tune after converting it to DSp5 it locks it and I have to open with V8 and clear restrictions, and it would not let me save it without my V2 connected when I was done. never had this happen before.
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    In the release notes we have this:
    IMPORTANT
    Your security restriction options on the [Permissions] tab page in the V7.5 Tune Tool software may change during the upgrade to this version of the V7.5 software. Please review those security restriction options and reconfigure them according to your preference.
    It is possibe, (probable even) that your security restrictions in the V7 tuning tool software have been changed during the update. Please make sure they are set like this, which is the default value:
    What happened in a previous version was the settings got saved incorrectly into the V7 registry. That meant when we corrected the bug in this version, there was no way for the softwar to automatically "fix" the settings. So we advise you to check them and set them to what you want them to be.
    You can use the V8 software to remove any security settings that got set when you saved the files using V7.
    Jan 2009
    Paul,
    I dont think the BBX quick setup is saving the security restrictions properly. The CTZ to COZ worked great however with the ctz if I save it as private and then export it to a folder I can still open it as none of the security flags are set. I would assume its the same for the .coz's.
    Mitch
    Hi Mitch,
    Security restriction changes are not "baked into" the tune files in the BBX list until the BBX file is saved. So if you change the restrictions, then export the file it will have the original restrictions that the file had when it was added to the BBX list.
    If you save the BBX file first, then re-open it (as would be the case if you sent it to a customer), then export the files you will see that the security restrictions are retained.
    Quote Originally Posted by Mitco39 View Post
    Paul,
    Mitch
    Jan 2009
    I tried that as well. I get the .coz cannot be opened error when trying to open that file. Thats if I double clicked the .bbx file in my windows explorer. If I open up the bbx file inside of V8 it opens up like you said it would in the post above. Is there a way to send this to the customer and just have them double click the bbx file and have it pop up the window for them to click program?
    Or maybe I am missing something.
    Everything else seems to work perfectly. I was also wondering is it possible to add in a feature that would update the autocal/v2 firmware to the current version of their software they have downloaded automatically? It would really make this a one or 2 click process for the customer if we were able to do that.
    Thanks a bunch Paul,
    Mitch
    Hi Mitch,
    You can't (yet) double click on a *.bbx file and have it open automatically. But we're working on it, so soon you will be able to do that.
    We have decided against automatically updating the firmware since it is impossible to downgrade the firmware once it has been updated. We have been asked about an auto firmware update option and we are still considering it. Meanwhile, the [Check Firmware] button on the main V8 Scan and Tune window is the quickest/simplest option for now.
    Jan 2009
    Makes sense Paul.
    Thanks so much for your quick replies. Finally just got on board with using this system as I have started doing more and more trucks and this is going to save me a huge amount of time especially now that we can go from ctz to coz inside this program.
    Next little question for you. Is it possible to hide all the read commands as well "switch tunes" option from the autocal as this confuses many customers. Again not a huge deal by any means, just adding suggestions haha.
    Thank you sir.
    Mitch
    Hi Mitch,
    You can't remove the read options from AutoCal.
    You can enable/disable the switching options for AutoCal.
    AutoCal settings are saved in the BBX quick setup file if you check the "Include current device settings" checkbox.
    Makes sense Paul.
    Thank you sir.
    Mitch
    Jan 2009
    Ah perfect. Thanks.
  1. Known issues with Mar 03, 2015 release of the EFILive software and firmware.
    Last Post: March 20th, 2015, 10:55 AM
  2. Known issues with Feb 14, 2015 release of the EFILive software and firmware.
    Last Post: March 3rd, 2015, 03:03 PM
  3. Known issues with Feb 09, 2015 release of the EFILive software and firmware.
    Last Post: February 12th, 2015, 08:04 AM
  4. Known issues with Jan 2015 release of the EFILive software and firmware.
    Last Post: February 4th, 2015, 06:55 PM
  5. March 05, 2011 release candidate 2
    Last Post: March 20th, 2011, 02:36 PM
