Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: New tuner need help with PID's
    May 2015
    Default New tuner need help with PID's
    I have gathered up all the Calc VE tutorials, Firstly I added the new PID's to the config file but when I went to open the scan part I got a error regarding the displacement LTFTBEN VE PID, it mentioned changing (displacement) to (5.669) tries this still an error? So I got the updated config file from the CALC.VE thread and went ahead into scan software to select the PID's required some were fine others had red crosses tried right click more info but didn't give any info of other PID's required? I also couldn't find some of the PID's such as Dynamic Air Temperature? Need all the help I can get, slowly getting my head around what the PID's do etc but not sure how to write them into the config file to get the information needed.
    What OS are you using (does it support the pid GM.DYNAIRTMP_DMA)...?
    Are you reading pOst #1 of Calc.VET thread...?
    Post some screenshots.
    What year/model/vehicle are you tuning...?
    May 2015
    When you say operating system are you talking efi live system or vehicle system. Car is a VZ 2004 SS Commodore LS1. I had a thought do I have to be plugged into the car to set all the PID's? Will get screen shots when I have some time this afternoon. Thanks for your help. I started first with PDF tutorial but am now following that thread you linked.
    OS = PCM's operating system (has a GM id number)(not to be confused with PCM part number).
    You can select pids offline and then connect to vehicle, but the first time you connect you should go Info->Validate Pids.
    May 2015
    Thanks will give this a try when I get back near the car, having trouble with my AEM wideband not being found going through the thread about it now think I have it worked out. blue wire (serial) to black wire pin one of RJ11 plug and earth to white wire pin 5 on RJ11 sound right I think I currently have it around the other way.
    May 2015
    Turns out had wiring wrong, I am getting the AFR reading but when logging it doesn't display anything on the PID? Anyone have a solution to this issue?
    May 2015
    Joe, here is my operating system 12592433, used the other config.txt file and I have all PID's except all the CALC ones? Where are they and why cant I find them in my PID list am I missing something?
    Are you using V7 scantool or V8 scantool...?
    Are you talking about V7 pid list or V8 pidlist...?
    Which config.txt file (post it here)...?
    Quote Originally Posted by jmsmotorsport View Post
    Are you looking at the pids EXT.WO2xxx...?
    May 2015
    I think I have sorted the W02 issue with a patch update, Im looking at the PID's in V7 Scantool. Using this config file
    https://forum.efilive.com/attachment...7&d=1364789407
    Its the second lot in the first post.
    https://forum.efilive.com/showthread...l=1#post135867
  1. calc.pid /sae.generic - pid resoultion question
    By cyipher in forum Gen III V8 Specific
    Last Post: February 6th, 2014, 01:00 PM
  2. 5.3 tuner?
    By Zebler in forum Gen III V8 Specific
    Last Post: July 11th, 2010, 06:53 PM
  3. e38 dma pid SCALEDCORVE_ doesnt work plus a bad calc pid
    By ringram in forum FlashScan V2 BB Logging
    Last Post: November 30th, 2008, 11:28 AM
  4. I wonder how the tuner did this......
    Last Post: August 25th, 2005, 11:15 AM
  5. Release of 98 tuner
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: December 3rd, 2004, 08:07 AM
