Results 1 to 10 of 13
Thread: Serial Wideband Issues after Update
    Mar 2009
    Default Serial Wideband Issues after Update
    So I've used the serial connection on and off for a few years on my Lc-1. I recently did an update for the flash scan and scan tool.
    Now when I select the Serial PIDs for both AFR and lambda, they come is available. The values also come through on the flash scan display.. However, I can't log them through pass through on the scan tool software. I followed the tutorial and still no luck.
    Ideas anyone?
    V8 S&T -> Devices -> Logging
    did you checkmark "Automatically log all external digital/serial pids"...?
    Mar 2009
    Yes, I did select it, but that didn't work.
    I think that may have been the ticket, gonna try again tomorrow or Monday. I downloaded the V7 from the web yesterday, and thought it would be current. But I did not select, check for updates within the scan tool afterwards. I did now, and a patch was downloaded and current with Build 283.
    Thanks Paul!
    Mar 2009
    I did go over the logs from earlier today, and noticed there are values for the W02 serial PIDs. They are just way off from where they should be. See attached log.
    a friend has a similar issue with his new device. I sent it my calibration data for pid list and it was good after that.
    Quote Originally Posted by LastCall View Post
    Which wideband do you have...?
    Did you configure V2 BBL for this wideband...?
    Can you capture a new log.
    Mar 2009
    What changes did you make? I was using the serial PID that EFIlive included with the scan tool.
    I have an LC-1. Yes, I did and it worked fine for a few years. Everything changed with the 7.5 and firmware updates. I did verify that the settings were correct in the V2 box. And I was getting the same values on the V2 box as my gauge. For some reason, it just wasn't making it's way into the scan tool.
    Yes, I'll do a new log.
    the problem with the data not coming through the software was actually something to do with the v2 unit data loaded.
    even though it was showing on the v2 unit itself correctly.
    See this:
  1. serial wideband
    By pdasterly in forum FlashScan V2
    Last Post: October 6th, 2013, 07:57 PM
  2. wideband serial cable
    By vcls1 in forum General
    Last Post: November 29th, 2012, 03:06 PM
  3. Wideband serial update
    Last Post: September 9th, 2010, 10:13 AM
  4. log serial wideband
    By b18cls1 in forum Black Box Logging
    Last Post: February 12th, 2010, 04:46 AM
  5. serial wideband
    By articSS in forum Black Box Logging
    Last Post: December 19th, 2008, 07:04 AM
