Results 1 to 9 of 9
Thread: Surging
    Nov 2011
    Default Surging
    I have a LMM that surges. The vanes are changing position while driving at steady speeds. Smoke then clean while they are changing. Where should I be looking for this problem? No script used, just single tune.
    Lifetime Member Road's Avatar
    Feb 2015
    Torque converter clutch slipping can cause the turbo to do that...
    Nov 2011
    No slip in TCC. It does through acceleration also.
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    If EGR controls are out of whack it can do that.
    Dan's Diesel Performance
    www.dansdieselperformance.com
    Dec 2013
    Is this tune calibrated to turn EGR off?
    Nov 2011
    They are off.
    Dec 2013
    Try turning the EGR option "on" but then go to settings for EGR operations and make the requirements unreasonable. IE: EGR will not operate until coolant temp reaches 300*.
    Mar 2015
    I'm also curious to know what the problem was with this truck...
    2007.5 Chevy C5500 6.6L Duramax LMM----Few Modifications----Used For Towing
    May 2014
    my guess is an EGR problem. some engines need a blocker plate and some do not. an EGR blocker might be helpful in your engine.
  1. Need Help with Surging Issue
    By BigCE in forum Cummins 5.9L
    Last Post: September 15th, 2014, 07:39 AM
  2. A little surging at startup....
    By tinindian in forum Gen III V8 Specific
    Last Post: May 26th, 2011, 12:42 AM
  3. TCC Surging...
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 17th, 2011, 03:26 PM
  4. Surging boost
    By LIL DAVE in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 29th, 2010, 09:16 AM
  5. Little surging issue
    By picnic_george in forum Gen III V8 Specific
    Last Post: December 8th, 2009, 07:42 AM
