Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
Thread: Can't load PIDS for BB log
  1. #31
    Jul 2005
    Well why didn't I think of that. Thank you very much Paul. Keeps a 70 year old out of the Florida heat when tinkering with the car.
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
  2. #32
    Member Dirktdolman's Avatar
    Oct 2014
    Ok I have a 03 Silverado 2500HD with the 6.0L and 4L80 Trans. So I have the LS1B. I am trying to follow the Calc.Vet process and come to the PIDs part. Of course the Tutorial was written with the 7.5 PID list. So I build my Calc.Vet.pid as the tutorial describes in 7.5 and save it. Now I can not save it to my V2. The "Program selected PIDs into the Flashscan" function is not enabled. How do I get the PIDs to the V2? I know use 8.0 but the tutorial is written with the PID labels and such in 7.5. They are not the same in 8.0
    2003 Chevrolet Silverado 2500HD 6.0L Automatic 4 X 4
  3. #33
    The option "Program selected PIDs into the Flashscan" is for FlashScan V1 black box logging.
    For FlashScan V2 black box logging you need to use the V8 option: [F5: BBX]->[F2: Scan].
    The documentation for BBL starts on page 37 of the V8 Reference Manual: Help->Documents->EFILive V8 Reference Manual.pdf
  4. #34
    Quote Originally Posted by Dirktdolman View Post
    To copy your PID selection from V7 to V8...
    You can highlight the PIDs in V7 and select the menu option "Edit->Copy for export to V8". Then in V8, right click in the green section of the V8 BBX Scan window and select Paste.
    That process translates PID names that have had been changed between V7 and V8.
  5. #35
    Oct 2014
    YOU ROCK, Thank you
  6. #36
    You can't use V8 to do any tuning like Calc.VET because V8 maps are not available yet.
  7. #37
    Regarding setting up V2 BBx pids, also see this: Setting-up-a-FSV2-from-scratch
  8. #38
    Oct 2014
    Ya that is funny
  9. #39
    Oct 2014
    Will V8 trim any PID which is feels does not work for your vehicle? The reason I ask is because I tried to copy 24 and only 17 were pasted.
    This is what is suggested to use and I tried to copy
    And this is what copies over
  10. #40
    Oct 2014
    Looks like these are the PIDs which did not copy and I can't find them in V8
  1. PIDs to log?
    By Mikz86ta in forum General (Petrol, Gas, Ethanol)
    Last Post: May 30th, 2013, 02:50 PM
  2. What pids do I need to log?
    By Cool28 in forum Gen III V8 Specific
    Last Post: November 22nd, 2011, 02:27 PM
  3. Replies: 2
    Last Post: September 8th, 2011, 11:07 PM
  4. Can't log some airflow PIDs
    By O1Z06 in forum Petrol / Gas
    Last Post: February 21st, 2011, 05:03 AM
  5. How do i setup my PIDs to log?
    By RyanU in forum External A/D inputs
    Last Post: September 5th, 2008, 10:17 AM
