am I missing something its not shifting into overdrive till over 6000 I set it at 5000 its a 5.3 in a s10 342 rear
It won't do WOT 3->4 because D0920 is set to 256 mph.
I see various other problems, and also with PE.
Ok I'll take care of that what do I need to do to the pe
B3616 PE Enable set at 90% TP is too restrictive... PE should enable easier, e.g. look st 2002 Camaro.
Ok thanks
