Results 1 to 4 of 4
Thread: Serial wideband not reading in scan V7.5 correctly
    Apr 2010
    Default Serial wideband not reading in scan V7.5 correctly
    Hi all,
    so before updating to the latest version of v7.5 and v8 and the firmware etc, my innovate MTX wideband connected fine to the flash scan and then read correctly in scan V7.5
    Now I can get the Wb hooked up to the flashscan and reading correctly (matches the MTX gauge), but the serial wideband pid just reads solid at 10?
    Is there an issue in V7.5 , d I have to migrate to scan in V8 now?
    Apr 2010
    Found a potential solution in another section, could be due to the latest update being build 282 NOT 283, so need to run updates in V7.5.
    Hopefully this solves the problem
    Let me know how it goes...
    Paul did fix a serial comms wideband problem.
  1. Replies: 9
    Last Post: November 16th, 2011, 03:17 AM
  2. LC-1 WO2AFR Serial Reading Low AFR
    By O1Z06 in forum FlashScan V2 BB Logging
    Last Post: April 9th, 2011, 03:37 PM
  3. not reading wideband
    By southern in forum FlashScan V1
    Last Post: April 1st, 2011, 06:45 AM
  4. RAFIG issues, scan tool doesnt track correctly
    By eurospec1 in forum Gen III V8 Specific
    Last Post: October 13th, 2007, 02:53 PM
  5. EFI not reading AFR correctly
    By billyjo in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2006, 10:55 AM
