Results 11 to 20 of 27
Thread: Known issues with July 08, 2015 Public Pre-Release
    Quote Originally Posted by MyM8V8 View Post
    Also this car does not have an ignition key, you have to have the fob in your pocket. You have to press the brake ( before pressing the dash mounted engine starter button).
    Holding your finger on the start button for about 5 seconds WITHOUT your foot on the brake is the equivalent of turning the IGN on with the old key systems, you need to do that.
    May 2007
    just done all the updates for july 8 and cant read my lm1 on scan tool.
    both efi 8(279) and 7.5 (286)are with latest updates.
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
    Nov 2005
    Quote Originally Posted by Aint Skeered View Post
    Have responded in your other thread with V8 Scan and Tune instructions on Wideband configuration.
    Cindy
    Senior Member MyM8V8's Avatar
    Aug 2008
    Hi Cindy,
    No I didn't try BBX so i'll give that a go, and the little lappy I use is very old so doubt it has USB3, probably USB2.
    Cheers G.
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
    Aug 2008
    Ah, OK, that's possibly why I had trouble getting into the TCM then?
    Thanks.
    Aug 2008
    Ah, OK. That's possibly why i had issues connecting to the TCM.
    Cheers G.
    Redline Motorsports
    Guest
    Not sure if tied to this release but having an issue with the compare feature. Its not showing all the items that are different. In addition same vehicle will not run when copy and pasting a know IFR table I have used forever..flip back to stock IFR car will run. This is not a matter of "calibration" but seems to be like something is not going into the right place.... this is just another day here with an E38 nothing new but chasing these issues...
    Quote Originally Posted by Redline Motorsports View Post
    I have had this happen also on several E38's and I am not on the current release.
  9. #19
    Can you please send me two *.ctz files that have differences that are not showing up in the compare?
    And can you also send me two *.ctz files, one before the IFR changes are pasted into it that does run and then the one with the IFR changes pasted into it that does not run?
    Thanks.
    Send to paul@efilive.com with a link to this thread.
  10. #20
    Member Dirktdolman's Avatar
    Oct 2014
    Did anyone else receive this message from their Anti-Virus?
Name:	Install Error.jpg
    2003 Chevrolet Silverado 2500HD 6.0L Automatic 4 X 4
  1. July 08, 2015: EFILive Public Pre-Release
    Last Post: July 27th, 2015, 05:59 PM
  2. Known issues with June 02, 2015 Public Release
    Last Post: July 8th, 2015, 05:07 PM
  3. Known issues with May 01, 2015 Public Release
    Last Post: June 2nd, 2015, 10:46 AM
  4. Known issues with April 13, 2015 Public Release
    Last Post: April 30th, 2015, 08:33 AM
  5. Public Release Update July 03, 2011
    Last Post: July 17th, 2011, 08:21 AM
