Results 1 to 9 of 9
Thread: Default Metric PIDs List
    Jul 2015
    Default Default Metric PIDs List
    Hello, Newbie here. Recently after updating software/firmware/bootblock etc with my V2 tried to datalog and all the preselected pids lists are missing. Can someone point me in the direction of a tutorial to allow me to reset the factory default metric pids list. Thx.
    In scantool, goto PIDs tab, click the open-multiple-folder icon, browse down until you see Default Metric.vdb, select it, click Ok.
    Jul 2015
    Sorry was away. Is it possible to get the file emailed for some reason its missing in the file directory/folder.
    swingtan
    Guest
    You should backup your V2 config files prior to updating, then restore afterwards.
    The file that has all of your PID lists is "options.txt".
    1. plug your V2 in to the computer.
    2. open EFILive "Scan & tune".
    3. Select "F5: BBX".
    4. Select "Read" to get the current list.
    5. In the "BBL Enabled Controlers" box, select the list you want to alter.
    6. Select the "V7" button on the right of the above box.
    7. in the "Default Dashboard" section, choose your required dash page.
    8. save all the settings.
    9. save the "options.txt" file to the PC as a backup.
    10. Program the controller.
    When performing a firmware update, backup the options.txt file first, then after the upgrade, use the "format CONFIG files system" under the "program" options to clear the current settings. Then open the saved "options.txt" file and reprogram the V2.
    Simon.
    Dutchman,
    are you talking about V2 BBX or V7 scantool...?
    Jul 2015
    Joe, I followed your directions could not locate the file you referenced either on the V2 SD card or EFILive Scan and Tune software files. My appologies I can't explain what happened to the .vdb file. I followed swingtans post directions and appear to have been able to create, save and back up the option.txt file that was missing from both the V2 BBX and EFILive Scan and Tune software. I was able to make a short datalog for my tuner today with what appears to be the reset Default Metric PIDS list, I'll advise my status when I hear back. Thanks Folks for the help so far.
    Default Metric.vdb is used by the V7 scantool...
    Jul 2015
    Hi Joe sorry, I was able to locate the file you referenced in the V7 Scantool. I'll give it a go today. Thx.
    Jul 2015
    Just heard back got it all sorted out the V2 BBX is functional, I can now data log again thanks folks!
  1. 1999 PCM wont validate Default Metric PIDS
    By bink in forum Petrol / Gas
    Last Post: September 10th, 2014, 01:50 PM
  2. Convert Pass Thru Scan PID list to BBL PID list
    By jrh in forum FlashScan V2 BB Logging
    Last Post: July 5th, 2011, 08:09 AM
  3. Some pids not available on default vs my pids
    By LS1Nova in forum General
    Last Post: July 19th, 2010, 10:45 AM
  4. Default set of PIDS
    By ahajr in forum FlashScan V2 BB Logging
    Last Post: June 14th, 2008, 06:11 PM
  5. Replies: 6
    Last Post: November 7th, 2005, 11:16 PM
