Those registration details are not correct. They do not match what we have on file for that FlashScan V1.2 device.
Please send your FlashScan authorization code to me at paul@efilive.com and I'll re-issue you with the correct registration details.
You can generate the authorization code using the V7 menu option: Help->FlashScan V1 PCM licensing... Then select the [Authenticate] tab page and click the [Copy] button to copy the "Auth code" then paste it into the email.
