Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
Thread: Improving WB Tune: Large difference in Min/Max + Suggested Values for TC+TF
    Jan 2007
    I've played around with it so much in the last weeks it is hard to know what all has and has not been done.
    At this point it rarely dies BUT it almost dies sometimes. Other times I come to a stop and it is perfect. I have finally tracked it down to the spark timing jumping down to almost nothing. No idea why it is. I wish there was a goto list of PIDs to log if you had problem X or something.
    Jan 2014
    Looks exactly like my issue I had where map ran to ambient and spark fell to crap because of it, along with rpm.
    I fixed it with TC and TF. Did you OS swap your truck?
    Jan 2007
    I wasn't sure if a custom OS was out for this truck. That might help.
    How much (max value) were you using? like .80 grams? 1.5 grams?
    Aug 2013
    What injectors are you using?
    Jan 2007
    LS2 Corvette injectors. Factory OEM Bosch.
    Aug 2013
    You're doing your power enrichment through your commanded fuel in open loop table rather than through the PE tables... why have you got it set up that way?
    Quote Originally Posted by statesman View Post
    He may be doing that from doing the old AutoVE procedure.
    I agree with you, he should be doing power enrichment thru the PE table (set EQR 1.175 for NA engine)...
    ( in OL the active fueling tables are the OLFA table and (when PE activates) the PE table... the richer current operating point/cell is selected from those tables )
    Quote Originally Posted by 2002_z28_six_speed View Post
    I have been doing a lot of work on this and making some progress.
    Ok, something I saw:
    you're setup to fail the MAF, but in C6001 the MAF DTC's are set to 2-Trip... you need to change these to 1-Trip or to Non-Emissions, and verify that on engine start you get an immediate MAF DTC...
    ( if you don't get an immediate MAF DTC (which is the case with 2-Trip), the PCM is still using the MAF (and if the MAF is not physically present the PCM calculates a "sane" value for the MAF and uses that)... so if you intend to run SD it is utmost that you see a MAF DTC )
  9. #19
    From B5916 and B5917 it looks like you never use the base spark tables, so all your spark would be coming from LO spark table B5914 (because you would have a MAF DTC)...
    so I suggest playing a little with the LO spark table...
    ( if you're not boosted, your spark table could be increased )
  10. #20
    Jan 2007
    Oh man! It looks like I am using an out of date document for the VE tuning process.
    Just tried searching the site a little bit --- Is there an official latest version with the basics of what to check for? I am beginning to understand I don't have all the puzzle pieces needed to finish this little project.
    Thanks to everyone for contributing your years of experience.
  1. Improving shifts via the ECM
    By GMPX in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: July 1st, 2022, 11:57 PM
  2. CLSD tune runs great 30 min later rich at idle
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2007, 12:57 AM
  3. Suggested seller (USA)
    By FeetDry in forum Purchase and Shipping
    Last Post: April 26th, 2007, 01:47 AM
  4. Replies: 0
    Last Post: February 6th, 2006, 10:12 AM
