Results 1 to 5 of 5
Thread: Wot Shift Problem
    Lifetime Member driver456's Avatar
    Default Wot Shift Problem
    When my MAF is hooked up My car will not shift at WOT,Does not idle right in gear or in neutral.When I disconnect it the car idles perfect,shifts right on time and the car just seems to run better.The trans seems to shift harder though at low rpm,I have a shift kit.Can I leave it disconnected,If so what do I have to do besides turning off the check engine light.97 C5 H/C headers.And my wide band still does not seem to be working.When I plug it in it reads "rich" for a split second then "14.67" but does not change when I go for a drive,.And yes I have to be careful on WOT till I fix it.
    Anybody??? I'm going to E-Town Saturday for the Corvette challange.I want to be ready
    Redline Motorsports
    Guest
    Give is more info! What is done to the car and what have you done with tuning thus far?
    Quote Originally Posted by Redline Motorsports
    It has H/C,headers,LS6 intake(97 C5 auto).I was in SD mode so I can work on my LTFT I made the shift tables low,because I noticed it wasn't shifting at WOT with the MAF meter hooked up,So I was wondering why is it shifting at WOT right on time without the MAF meter hooked up,And not shifting at WOT with it hooked up.I also put in a shift kit.
    Anybody??????
  1. 02 duramax shift problem
    By iowatruckpower in forum Allison 5 & 6 Speed
    Last Post: February 13th, 2009, 09:53 AM
  2. PID Problem w/BBB - Asked by Cougar 281 (FRPDES problem)
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 02:02 PM
  3. why 1>2 shift happens at higher rpm than 2>3 shift?
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 13th, 2008, 11:54 AM
  4. WOT Shift, 1-2, 2-3
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 25th, 2008, 01:24 PM
  5. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 05:49 AM
