Results 1 to 10 of 16
Thread: EFILive Flashscan V1 Commercial Upgrade License. Now Scan Only.
    Oct 2007
    Default EFILive Flashscan V1 Commercial Upgrade License. Now Scan Only.
    I sent in my V1 serial number to request an upgrade from Personal Scan&Tune to Commercial Scan&Tune and received an email with the following information/instructions. I was not successful with the upgrade and after several email exchanges I started to believe there might be something missing, probably the Activation Code. If someone has completed this upgrade recently would you mind letting me know if the document is complete or not and I'll let Donna know.
    ____________________
    Dear Larry,
    Please keep a record of these details in a secure place.
    Your EFILive V1 Commercial upgrade Activation Code is: <-
    EFILive Order Number:
    EFILive FlashScan Serial Number: 003480749632
    Personal Upgrade Code: 00D4929D
    Commercial upgrade Code: 0B3A54D4
    Your EFILive V7 Registration Details are:
    [License.1]
    Serial=003480749632
    RoadRunner=
    Type=Commercial Scan&Tune
    Issued=20151011
    Key=WWZF-PGMP-PKFF-PVCF
    Make sure you enter the registration details exactly as they appear in this
    email.
    Take particular care to enter the date correctly. The date is shown above
    in the form YYYYMMDD. For example, 20151011 means Oct 11, 2015.
    Once entered into EFILive V7, the license details are stored in the file:
    \My Documents\EFILive\V7.5\User Configuration\License.txt.
    Follow these instructions to upgrade your interface cable to "Commercial Scan
    And Tune".
    1. Connect the FlashScan V1 cable to yo! ur PC, but not to any vehicle.
    2. Start the EFILive Tuning Tool software.
    3. Select the menu option: "Help->FlashScan V1 PCM Licensing..."
    4. Select the [Upgrade Cable] tab page.
    5. Enter your Personal Upgrade Code in the "to Personal:" text box.
    6. Click on the [Upgrade] button nearest the "to Personal:" text box.
    7. Enter your Commercial Upgrade Code in the "to Commercial:" text box.
    8. Click on the [Upgrade] button nearest the "to Commercial:" text box.
    9. Close the "FlashScan License" window.
    10. Close and restart the EFILive Tuning Tool software.
    Verify that the following Commercial features are now available.
    1. Select the menu option: "Help->FlashScan V1 PCM Licensing..."
    2. Verify that the "FlashScan License:" is set to "Commercial Scan&Tune".
    3. Close the window.
    4. Open the 2002_CorvetteZ06_LS1.tun file using the menu: File->Open tuning
    file...
    5. Make sure you can view the Electronic Throttle Control tables her! e: Engine
    Calibration->Electronic Throttle.
    6. Click the full-flash icon in the toolbar. It is just to the right of the
    normal flash toolbar icon. You should see a full reflash window appear.
    Click OK and close the full flash window.
    7. With FlashScan connected to your PCM and the vehicle's ignition turned on,
    open the PCM Locking window. Make sure that the [Lock] button is now enabled. Do
    not click the [Lock] button unless you really do wish to lock your PCM.
    Thank you for choosing to upgrade to EFILive V7 commercial.
    Donna Blackmore
    EFILive Limited
    Thank You,
    My64
    Ok, I notified EFILive of the missing activation code.
    The upgrade codes in the email are correct for your device:
    Make sure you use the digit zero, not the letter "O" for the leading zeros (although leading zeros can actually be omitted).
    Please see the two images below that show what you should expect to see before upgrading to Commercial and after upgrading to Commercial.
    Oct 2007
    Paul,
    I cannot enter the Personal Upgrade Code: "00D4929D" the box is not activated. The top image "Before" in your post is identical to what I'm seeing. The text "Commercial" very dark and "Personal' is greyed out and will not accept text entry. I have no problems with entering the Commercial upgrade Code: "0B3A54D4". The question is about the "EFILive V1 Commercial upgrade Activation Code". This line, in my previous post, of your email lacks an Activation Code "Your EFILive V1 Commercial upgrade Activation Code is:________________". Please provide if needed. if not, please indicate that it's not required.
    Thanks,
    My64
    The Personal activation code is only for upgrading from "Scan and Tune" to "Personal". If your device is already at "Personal" (as it appears yours is), then you only need to enter the Commercial upgrade code (i.e. 0B3A54D4) to upgrade from "Personal" to "Commercial". Once you do that then both the Personal and Commercial upgrade options will become greyed out indicating that the device has been successfully upgraded to Commercial.
    Oct 2007
    Paul,
    I've tried every suggestion you have offered including the instructions included in the email, which now seem to be wrong, with no success.
    Three times I've asked you about the EFILive V1 Commercial upgrade Activation Code. and you have never replied. I'm asking for the fourth time is it necessary?
    Thank You,
    My64
    Quote Originally Posted by MY64 View Post
    Paul,
    Thank You,
    My64
    Well I guess I don't understand what the problem is. From everything I've read that you've posted, I believe (and I could be wrong) that you are trying to upgrade your V1 Personal to Commercial. To do that, simply enter your Commercial upgrade code (which is 0B3A54D4), into the field labeled "to Commercial" then click the [Upgrade] button to the right of that field. That's all you need to do.
    If there's something else that doesn't work or doesn't make sense or if I've misunderstood the problem, please try to explain the exact problem to me again. Include as much information about what you are trying to achieve and what you have tried that has failed.
    The activation code is this: 0B3A54D4
    The email is confusing. Sorry, I'll get it re-worded.
    I have now removed the line that says this:
    And I have change the wording of the instructions to this:
    Follow these instructions to upgrade your interface cable to "Commercial Scan And Tune".
    1. Connect the FlashScan V1 cable to your PC, but not to any vehicle.
    5. If upgrading from Personal to Commercial skip to step 8
    6. Enter your Personal Upgrade Code in the "to Personal:" text box.
    7. Click on the [Upgrade] button nearest the "to Personal:" text box.
    8. Enter your Commercial Upgrade Code in the "to Commercial:" text box.
    9. Click on the [Upgrade] button nearest the "to Commercial:" text box.
    10. Close the "FlashScan License" window.
    11. Close and restart the EFILive Tuning Tool software.
    I hope that makes it a bit clearer.
    Oct 2007
    Paul,
    That makes it much clearer and yes I'm attempting to upgrade from Personal Scan&Tune to Commercial.
    1. I verified that the registration details in the "\My Documents\EFILive\V7.5\User Configuration\License.txt" are correct after replacing the Personal Registration Details with the following:
    [License.1]
    Serial=003480749632
    RoadRunner=
    Issued=20151011
    2. The V1 cable is connected to the PC with no vehicle attached.
    3. Using the Commercial Upgrade Code 0B3A54D4 (using Caps and a 0 not an o) and clicking on the Upgrade Button I'm getting the following reply: FlashScan was not Upgraded. Please check the Upgrade Code that you entered, is correct.
    Thank You,
    My64
    If you have not already done so, could you please try the other code in the "to Commercial" field, just in case they are the wrong way around in the email?
    Not sure what you mean by "using Caps". That makes me think you are using an uppercase letter "Oh". The first character of the code is the digit zero, not a letter. The codes always consist of only the digits 0 to 9 and the letters A to F.
    Lastly can you confirm that the serial number of your device really is 003480749632
  1. FlashScan V2 Scan Only Upgrade to Tuning
    By TDH in forum FlashScan V2
    Last Post: February 11th, 2015, 10:03 AM
  2. Flashscan V1 Scan and Tune License Question.
    By eesimpkins in forum FlashScan V1
    Last Post: December 1st, 2010, 07:37 AM
  3. Got efilive, license says scan only
    By SScarTuning in forum General (Petrol, Gas, Ethanol)
    Last Post: November 1st, 2007, 01:15 PM
  4. Flashscan vs HPTuners? Upgrade from EFILive
    By Iv_z28 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 12th, 2004, 11:29 PM
  5. EFILive FlashScan upgrade price
    Last Post: November 22nd, 2004, 01:21 PM
