I sent in my V1 serial number to request an upgrade from Personal Scan&Tune to Commercial Scan&Tune and received an email with the following information/instructions. I was not successful with the upgrade and after several email exchanges I started to believe there might be something missing, probably the Activation Code. If someone has completed this upgrade recently would you mind letting me know if the document is complete or not and I'll let Donna know.
____________________
Dear Larry,
Please keep a record of these details in a secure place.
Your EFILive V1 Commercial upgrade Activation Code is: <-
EFILive Order Number:
EFILive FlashScan Serial Number: 003480749632
Personal Upgrade Code: 00D4929D
Commercial upgrade Code: 0B3A54D4
Your EFILive V7 Registration Details are:
[License.1]
Serial=003480749632
RoadRunner=
Type=Commercial Scan&Tune
Issued=20151011
Key=WWZF-PGMP-PKFF-PVCF
Make sure you enter the registration details exactly as they appear in this
email.
Take particular care to enter the date correctly. The date is shown above
in the form YYYYMMDD. For example, 20151011 means Oct 11, 2015.
Once entered into EFILive V7, the license details are stored in the file:
\My Documents\EFILive\V7.5\User Configuration\License.txt.
Follow these instructions to upgrade your interface cable to "Commercial Scan
And Tune".
1. Connect the FlashScan V1 cable to yo! ur PC, but not to any vehicle.
2. Start the EFILive Tuning Tool software.
3. Select the menu option: "Help->FlashScan V1 PCM Licensing..."
4. Select the [Upgrade Cable] tab page.
5. Enter your Personal Upgrade Code in the "to Personal:" text box.
6. Click on the [Upgrade] button nearest the "to Personal:" text box.
7. Enter your Commercial Upgrade Code in the "to Commercial:" text box.
8. Click on the [Upgrade] button nearest the "to Commercial:" text box.
9. Close the "FlashScan License" window.
10. Close and restart the EFILive Tuning Tool software.
Verify that the following Commercial features are now available.
1. Select the menu option: "Help->FlashScan V1 PCM Licensing..."
2. Verify that the "FlashScan License:" is set to "Commercial Scan&Tune".
3. Close the window.
4. Open the 2002_CorvetteZ06_LS1.tun file using the menu: File->Open tuning
file...
5. Make sure you can view the Electronic Throttle Control tables her! e: Engine
Calibration->Electronic Throttle.
6. Click the full-flash icon in the toolbar. It is just to the right of the
normal flash toolbar icon. You should see a full reflash window appear.
Click OK and close the full flash window.
7. With FlashScan connected to your PCM and the vehicle's ignition turned on,
open the PCM Locking window. Make sure that the [Lock] button is now enabled. Do
not click the [Lock] button unless you really do wish to lock your PCM.
Thank you for choosing to upgrade to EFILive V7 commercial.
Donna Blackmore
EFILive Limited
Thank You,
My64
