Results 1 to 9 of 9
Thread: Logging 2 LC2s in series.
    Jul 2007
    Default Logging 2 LC2s in series.
    I have made a serial cable that works well for the LC2. No problem, except I have one in each bank. I noticed that the LC2 out and the LC2 in connectors are the same.
    Should I connect the OUT of one LC2 to the IN of the other by making my own molex adaptor or is there another ? I would prefer stay serial cable vs using the AD inputs for this.
    07 Silverado DMax Classic
    Jul 2007
    Anyone know what the molex part number is for the in and out serial lines?
    Jul 2007
    Thanks, was looking for the male part. Found it at digikey:
    http://www.digikey.com/product-detai...2491?WT.srch=1
    Jul 2003
    i can get you a molex to molex cable if you need.... should work out fine.
    Jul 2007
    Ok, I have 2 - LC2s. I connected OUT1 to IN2. OUT2 -> Serial connector on top of V2. I only see one wideband on the log. I have both Serial1 and 2 selected in the PIDSs. On the V2 handheld, only 1 is recognized also(display setup for 2). Ideas?.
    edit: they both work via analog
    Jul 2003
    You have to log in to logworks to set which is master and which is slave. In the end it will be out 2-> in 1-> v2
    Jul 2007
    I checked LM Programmer and Logworks and there is no mention option I can see that has MASTER or SLAVE settings. Please specify how I get to this option. I just download the Logworks from their site.
    Jul 2007
    Here is how to make it daisy chain and show up in EFI's Log and on the V2. (I never found a SLAVE/MASTER setting as indicated above so I guess it isn't needed; user above can explain this procedure)
    Yep, all you really do is connect the two.
    If using two LC2s:
    1. Make a Molex connector that will join the IN and OUTs.
    2. Connect OUT2 -> IN1 and OUT1 -> V2 SERIAL PORT; Note that IN2 is not used and it DOES NOT have to be terminated like the LC1.
    3. Go to the Ver 7 EFI Scan tool, PID Tab, System Drop Down Box, WO2-Serial. Select EXT.WO2AF1 and EXT.WO2AFR2
    Test time in am...
  1. Vs V8 Series 3
    By limited cv8r in forum EFILive V4
    Last Post: September 10th, 2013, 12:46 PM
  2. Gen5 LTx series
    By ringram in forum Lounge
    Last Post: December 29th, 2012, 01:31 PM
  3. VY SS Series 2 Stock Tune
    By mk13 in forum Gen III V8 Specific
    Last Post: March 1st, 2011, 05:23 PM
  4. VY Series 2 V8
    By WestieVYCalais in forum EFILive V4
    Last Post: February 16th, 2009, 07:50 AM
  5. 3800 series II
    By DURAtotheMAX in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2007, 05:06 PM
