Results 1 to 5 of 5
Thread: Bootloader locked on LS1B using V1.2
    Junior Member Dewglass's Avatar
    Nov 2010
    Default Bootloader locked on LS1B using V1.2
    Just trying to read LS1B PCM and get the "bootloader locked" pop up. PCM checks out okay. -I was in this PCM in the past with no connectivity issues.
    When checking PCM security- it states PCM secured with a custom key. Tried various iterations eg. alt key on, high speed unchecked, 00000, $FFFF, FFFF, 00001 etc..
    Updated to latest v7.5.7 build 282 with no luck.
    Downloaded zip file from $0333 thread with no luck.
    Any foreseeable workarounds?
    Doug E
    '02 S10 Xtreme 4.3 Syclone power; AWD, 4L60E; 411 PCM: Walbro 255; 160F thermo: Front coil overs, 4" static drop;
    Hey Doug,
    Ok, thanks, I sent Paul a pm to this.
    Please update to this release: https://forum.efilive.com/showthread...ic-Pre-Release
    Then retry reading the LS1 PCM.
    Then locate and send the trace file from the failed read attempt to me at paul@efilive.com (include a link to this thread).
    More info on trace files: https://support.efilive.com/kb_artic...8552-EOAJ-5912
    See the section headed: Read/Flash Trace Files (V7 only)
    Nov 2010
    Thanks guys for helping get this resolved.
    The key Paul sent worked.
    Ok, good deal
  1. LS1B PCM locked with a custom key
    By 400ss in forum Gen III V8 Specific
    Last Post: April 24th, 2015, 04:02 PM
  2. LS1B PCM locked
    By C5 Pete in forum Gen IV V8 Specific
    Last Post: July 23rd, 2014, 06:38 AM
  3. ecm locked bootloader rejected
    By jason86 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 1st, 2009, 02:06 PM
  4. bootloader rejected PCM locked
    By rubbersidedown in forum Gen III V8 Specific
    Last Post: July 30th, 2008, 10:16 AM
  5. Bootloader-
    By GMjohn in forum E37, E38 & E67 PFI ECM's
    Last Post: November 28th, 2007, 08:30 PM
