Thread: V2 Issue w/AD Ports
    Jul 2007
    Default V2 Issue w/AD Ports
    So, I have 2 serial Widebands and 3 AD inputs. When I plug in the sensors for AD ports, and click record, logging won't start. As soon as I remove
    the AD connection, the log starts. Anyone had this problem?
    07 Silverado DMax Classic
    Which V2 firmware version...?
    ( which V8 build version...? )
    Are you logging with V7 or V8...?
    What is the voltage range of each of the devices you have connected to the AD inputs...?
    Jul 2007
    Firmware 2.07.91 V7 Build 293. and 0 to 5v.
    This update fixes that problem:
    https://forum.efilive.com/showthread...ic-Pre-Release
    This is the comment about it in the "what's new" doc:
    Fixed “Negative Response Error/5” when starting a pass-thru data log while AD1 is connected to a voltage signal of 1.2V or more.
    If you need to log the AD inputs before you have a chance to update, you can start logging, pause the log, then connect the AD voltages, then continue logging.
    Jul 2007
    Downloaded. Thanks.
  1. Wierd issue after flash, airbag light on & oil reset issue
    By Tool Guy in forum Gen III V8 Specific
    Last Post: October 1st, 2013, 06:55 PM
  2. Replies: 21
    Last Post: July 7th, 2013, 11:31 AM
  3. No ports displayed in the device manager
    By Trippin in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 9th, 2008, 07:35 AM
  4. issue with 7.4
    By mr.prick in forum General (Petrol, Gas, Ethanol)
    Last Post: July 10th, 2008, 04:51 PM
  5. 2 OBDII Ports???
    By kbracing96 in forum General
    Last Post: August 31st, 2006, 05:28 AM
