Results 1 to 5 of 5
Thread: Custom Dashboard Logging Issue
    Junior Member PHLTHS's Avatar
    Dec 2014
    Default Custom Dashboard Logging Issue
    Hi All
    I've been trying to get my Custom Dashboards to work correctly without any luck. I have 4 PID's enabled on my V2.
    I'm currently running Firmware: 2.07.82 on the V2 and V7.5.7 (Build 282) and V8.2.2 (Build 276)
    1: LS1 AUTO MAF
    2: LS1 AUTO MAFLESS
    3: LS1 MANU MAFLESS
    4: LS1 MANU MAF
    MY PID FILE OUTPUT:
    ;Caption Active Modules (Engine&Trans) Hot Key Dashboard
    LS1 AUTO|MAF, Y, LS1B_M, , "LS1 AUTO MAF LTFT.vdb"
    LS1 AUTO|MAFLESS, Y, LS1B_M, , "LS1 AUTO MAFLESS LTFT.vdb"
    LS1 MANU|MAFLESS, Y, LS1B_M, , "LS1 MANU MAFLESS LTFT.vdb"
    LS1 MANU|MAF, Y, LS1B_M, , "LS1 MANU MAF LTFT.vdb"
    When I manually open my custom dashboards, they work perfectly. I'm pretty sure I have figured it out, for some reason the scan files are not having the correct "DASHBOARD=" value set as shown below.
    COUNT=0
    [DATA],6
    DASHBOARD=
    PIDCOUNT=19
    CHANNELCOUNT=26
    FRAMECOUNT=00000374
    STARTDATE=2457334
    Any idea's on what I can do to fix this? I have tried to uninstall and reinstall V8 and V7.5 with no luck.
    I've been working with swingtan and he suggested I post in the forum.
    Thank you for your help.
    Thanks for the detailed info. I can reproduce the problem here. It is a bug on the V2 firmware. It will be fixed in the next update.
    Dec 2014
    Hi Paul
    Thanks for the fast response. Is there any ETA on when the next firmware will be released?
    Thank you.
    It is scheduled for this week.
    Dec 2014
    That's great Paul.
    Thank you very much for the fast response.
    Cheers.
  1. Dashboard guages issue
    By azzhauler in forum FlashScan V2 BB Logging
    Last Post: May 30th, 2008, 06:18 AM
  2. PSL Logging issue
    By Cougar281 in forum FlashScan V2 BB Logging
    Last Post: April 29th, 2008, 12:30 AM
  3. probloms building a custom dashboard
    By sweetdiesel in forum General
    Last Post: June 8th, 2007, 03:43 AM
  4. Custom dashboard
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2006, 05:32 PM
  5. Custom Dashboard
    By mnotx in forum General
    Last Post: October 2nd, 2005, 04:15 AM
Tags for this Thread
