Before I go down the rabbit hole chasing this code.
Is P0650 a code set by running a COS3 setup?
I have always had the code set since I had the truck but I need to start setting up my truck to pass emissions shortly. ( I have that effort on lock but this code CEL light operation is unrelated to emissions equipment.)
I understand the PCM grounds pin 46 on C2 to control the light. So far the symptom is pointing to a wiring fault.
The CEL doesn't turn on when I turn the key on engine off, BUT it does turn on once I start the engine and stays on constant as long as the engine is running. WTF over.
I cannot command the CEL on/off with the FS2 or any other scanner. Is there an EFIlive COS default I am missing?
