Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Autocal and external wideband using serial comms
    Apr 2010
    Default Autocal and external wideband using serial comms
    hey guys. Bit of help if anyone can. Trying to get a autocal to log and external WB PLX on serial. Iam on the RX/TX with ground on the Autocal board.
    Brought in external serial via V8...get nothing but gook as far as afr readings....
    Has anyone been successful with this? If so...got some pointers?
    Did you swap Tx/Tx (i.e. null modem style)...?
    ( is AutoCal able to read serial comms from wideband...? )
    Apr 2010
    reckon that is where Iam on the wrong page...any condense veiw on wiring that in on a PLX?
    Oct 2006
    Have you had a read through this John? https://forum.efilive.com/showthread...ght=plx+serial
    The Tremor at AIR
    Apr 2010
    Quote Originally Posted by 5.7ute View Post
    I did start to but need the abridged (condensed) version...too many pages!
    Any one got a summary?
    Yes, but you have to modify the autocal for it to work.
    I didn't think the autocal supported external wideband via serial or analog?
    Apr 2010
    well Dave it does. That is why Iam trying to hooking it up.
    Quote Originally Posted by HOWQUICK View Post
    Well that's good to hear, something must have changed recently then as I wasn't aware of any official announcements.
    Going back to a thread in 2011, the following was mentioned.
    At the risk of being a downer I don't think this is something that will be on the to-do list anytime soon. The AutoCal (rightly or wrongly) was designed and specified to not include a serial (or analogue) wideband connection. Please also consider that while Innovate is likely to represent a reasonable proportion of what customers are using it is just one of many wideband controllers that are out there.
    https://forum.efilive.com/showthread...2-Just-an-idea
  1. Replies: 13
    Last Post: July 14th, 2012, 03:07 AM
  2. How to: Adjust External Calc: Wideband O2 Setting form my .?
    By Earl H in forum General (Petrol, Gas, Ethanol)
    Last Post: November 23rd, 2009, 01:59 PM
  3. HELP! No external voltage!
    By gotabav in forum General (Petrol, Gas, Ethanol)
    Last Post: May 13th, 2008, 10:52 PM
  4. External input
    By heavymetals in forum External A/D inputs
    Last Post: May 2nd, 2006, 04:44 AM
