I swapped my tranny for a manual G56 but because I changed the ecm. I need to clear some codes because of the different vin numbers.
One code I need to change is U0121 for my abs brakes, need to put a good code to clear it or what else can I do?
Any particular reason you changed the ecm, when a simple OS change would have worked?
Les Szmidt
2007 5.9 Dodge Ram
EFI Live Cummins BETA Tester
Silver Bullet Tuning
silverbullettuning@gmail.com
www.youtube.com/ljszmidt
A simple flash of a manual transmission operating system and of course the wiring part and your done. No need to get a manual transmission specific ecm.
Les Szmidt
2007 5.9 Dodge Ram
How would I go abouts doing that with out changing the vin?
You'll have to change the Vin but if you can change the OS, then a Vin swap is easy
Les Szmidt
2007 5.9 Dodge Ram
plus one... what i did
2006 Cummins Red, Auto to Nv5600, SBC 3600, Traction Bars, Visor, Running Lights, S&B Intake, ATS intake horn, EFI Live, Borg Warner S363 Turbo, Industrial Injection Dragon Fly Injectors.
Well then I could do a vin swap on my manual transmission ecm.
So all I would do is load in the manuals os into my original ecm.
