Results 1 to 10 of 16
Thread: 15 Supercharged Chevy SS - MAF is fine, VVE is fine, together they are not fine
    Apr 2007
    Default 15 Supercharged Chevy SS - MAF is fine, VVE is fine, together they are not fine
    15 Chevy SS, manual transmission,, LSA supercharger with 2.55" pulley, BTR PD supercharger cam, 60lb injectors, stock MAF. I have dual LC2 widebands and created a calculated PID that compares the average of both banks to the commanded AFR.
    I have a fair amount of tuning experience, but none with the e38 controller and none with efiLive.
    Installed the mechanicals and everything is working well. I know I have the correct fuel injector data.
    The tune is far from complete, but I have set about dialing in the VVE and MAF and both are to the point where the error is within a fairly small range.
    With the car in VVE only mode it runs very well and goes to wot nicely.
    With the car in MAF only mode (B8024 and B8025 set to 0) it runs very well (although it tends to run very rich at idle on initial startup) and goes to wot nicely.
    With the car in "normal" mode - VVE and MAF working together factory style it runs very well until you go WOT and then the AFRs spike very lean - very lean.
    Attached are the 3 latest versions of the tune (I disabled LTFT on all of them):
    Here is a scan showing the AFRs going sky high:
    I know I am missing something, but I am not sure what it is.
    I appreciate any advice. Thanks.
    When you tuned VE/VVE, did you make sure a MAF DTC showed up (immediately)...?
    Is FPR un-referenced or is it manifold-referenced...?
    Apr 2007
    I did make sure that the MAF fails when tuning VVE
    The FPR is set up as it was stock, un-referenced (the IFR changes with fuel pressure).
    I have no fueling issues when running MAF open or closed loop or SD open or closed loop.
    It seems to be happening when going into boost from relatively low RPM.
    Do you have any log files of VE+MAF showing this...
    Apr 2007
    Attached is the log that I took the above snapshot from, along with 2 others that I did immediately afterwords , one MAF only and the other mafless.
    Apr 2007
    I now understand a little better what is happening, although I still don't understand why it is happening.
    What seems to be going on is that whenever it is in blended mode, going to WOT causes fueling to be way off in the lean direction.
    When the PCM is in MAF only or VVE only this does not happen.
    I set up several tunes which set the transition to maf only B8024 and B8025 at various points (I put B8025 a few hundred RPM under B8024), from the stock setting of 4000 and then 3500, 3000, 2500, 2000 and 1500) The 1500 rpm tune is attached.
    I then ran a quick log with each tune and any time the PCM goes into WOT or PE BEFORE the transition point it goes very lean - the commanded AFR is fine, but the actual fuel delivered obviously isn't, any time that the PCM goes into WOT or PE AFTER the transition point it is fine.
    I would prefer to use the stock-like blended system, but I can't figure out why it doesn't like WOT.
    I'm looking at your 01-17 files...
    Apr 2007
    Thank you; I appreciate any ideas you might have.
    Hmmm, your wideband waveforms are hard to read, even in the logs from post #5...
    I thought I could read them, but when I saw your 01-17 logs I'm having trouble...
    and both widebands agree with each other.
    Try this: use LM Programmer to set both widebands to 1/6th averaging, let's see if this improves their output.
    Apr 2007
    Interesting, the widebands are crystal clear to me and they are independent of one another. The AFR Error is a custom PID.
    Post a screenshot of what you are seeing.
    When the problem arises you can feel it quite distinctively.
  1. trying to do a little fine tuning with no wideband
    By loganlewis in forum Gen III V8 Specific
    Last Post: October 25th, 2012, 09:04 AM
  2. Truck was running fine now getting these codes?
    By lstruck in forum Tutorials
    Last Post: October 19th, 2012, 05:01 AM
  3. RTACS fine/coursse control
    By tazinhawaii in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 8th, 2007, 11:40 AM
  4. Fine tuning AFR in PE
    By 12sec.5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 25th, 2006, 03:08 PM
  5. Idles fine till I turn on AC
    By skippy in forum General (Petrol, Gas, Ethanol)
    Last Post: June 8th, 2006, 04:02 AM
