Page 33 of 36 FirstFirst ... 233132333435 ... LastLast
Results 321 to 330 of 355
Thread: Custom OS#5
  1. #321
    Quote Originally Posted by whackem04 View Post
    Whats the best way to populate the TPS map at the hard to reach, low TP high RPM area?
    Eyeball extrapolation.
  2. #322
    I've read the tutorials and every thread related to OS5.
    I cannot figure out how the table "Commanded Fuel vs RPM (Normal) should be set or it's function. {B3647}
    I am setting up my PCM for simple nitrous spark retard. I think I have told the new OS to ignore TPS VE (Disable)
    The tutorial talks about B3647 a bit and suggests initial settings. But I have not read on here that anyone has modified this table and or if it should just be set to 1.0
    Any tips?
    the B3647 has me stumped.
    I don't have B3660
    My original OS was 12212156
    thanks,
    Karl Ellwein
    www.EllweinEngines.com
    Personal cars:
    95 impala SS running on an old Speed Pro PCM (Budget 355 LT1)
    Customer cars:
    96 impala SS, LT1-395ci, 4L60E, Stock LT1 PCM
    96 impala SS, LT1-399ci, 4L60E, BP Harness to 0411 PCM and 24x EFI Connection components
    95 impala SS, LT1-395ci, 4L60E, Re-Pinned stock harness to 0411 PCM and 24x EFI Connection components
  3. #323
    Jul 2007
    Quote Originally Posted by Ellwein Engines View Post
    Any tips?
    I don't have B3660
    thanks,
    Karl Ellwein
    send me your email addr, I'll send you a copy of my tune setup for nitrous, OL, No Trims, No MAF. It will give you an idea. BTW, I would leave 3647 alone unless you are VE tuning.
    07 Silverado DMax Classic
  4. #324
    Quote Originally Posted by TFZ_Z06 View Post
    Thanks, the comparison will help a lot.
    karl@ellweinengines.com
    Personal cars:
    Customer cars:
  5. #325
    B3647 is the OL fueling table, it is used only in OL. If PE enables during OL then the richest of the two is selected (at the current operating cell).
    B3647 is not used when you go from CL to WOT as in this case the residual LTFT is applied to WOT (i.e. in this case WOT is a reduced CL mode where even tho trims are not updated and applied, the last residual trim is applied).
    You could do any of these:
    a. set B3647 to EQR 1.0 everywhere (and make sure PE enables and is suitably rich at EQR 1.175 for NA).
    b. set B3647 to EQR 1.0 below 75 kPa, and then ramp it up to EQR 1.175 (regardless of whether PE has enabled yet).
    For NA you could have either PE and/or the high MAP columns of B3647 provide high load fueling.
    For boost, you would enable PE at 105 kPa and set PE fuel suitably rich for boost.
    Using B3647 means you will have to play with the OL ECT correction table A0008 (introduced by the COS in the A segment).
    Last edited by joecar; January 25th, 2016 at 02:24 PM. Reason: added id of OL ECT correction table
  6. #326
    thanks a lot. That helps. Thanks Joecar and thanks TFZ_ZO6 for the file to let me compare.
    Personal cars:
    Customer cars:
  7. #327
    One more question:
    If you had an OK tune for B3647 for the car prior to installing the custom OS5 then would you paste that old table into new OS5 B3647 table as a starting point?
    Personal cars:
    Customer cars:
  8. #328
    One more question:
    The GM OS does not have table B3647...
    When you install the COS, it replaces B3605 (which is ECT x MAP) with B3647 (which is RPM x MAP), and it retains the old data that B3605 contained...
    so your new B3647 looks like the old B3605, but because the vertical axis now RPM (instead of ECT), the data in this table is not completely sensible, you have to edit it (see my suggestions above).
    i.e. B3647 occupies the same space as B3605, but it changes the vertical axis from ECT to RPM, so the ECT x MAP data is not valid, you have to edit it into sensible RPM x MAP data.
  9. #329
    AhHa! that makes it even more clear. Thank you so much joecar.
    Personal cars:
    Customer cars:
  10. #330
    No worries let me know how it goes.
  1. Two PCM's with same Custom OS HELP
    By superspeed in forum Gen III V8 Specific
    Last Post: February 1st, 2009, 02:45 PM
  2. custom OS with efi v1
    By dsmlights in forum Custom Operating Systems
    Last Post: December 5th, 2007, 07:28 PM
  3. Why LM-1 Custom PID???????
    By 2002_z28_six_speed in forum General
    Last Post: June 4th, 2007, 12:52 AM
  4. Custom Os???
    By FFP in forum Custom Operating Systems
    Last Post: December 7th, 2006, 01:11 PM
