Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Car loses some functions because when V2 is connected
    I have identified a potential config setup in the FlashScan firmware that may be responsible for interference on the low speed CAN bus. Please use EFILive_Explorer to program in the attached firmware update into your FlashScan. This update has the same version number as the latest release (V2.07.95) so that you can swap between this firmware and the release firmware. The date on this firmware is Jan 25, 2016 so you can tell it apart from the release firmware.
    Apr 2008
    will update it today and let you know ...
    Regards,
    Odd Boy
    Apr 2008
    it is the same
    Regards,
    Odd Boy
    Quote Originally Posted by odd boy View Post
    it is the same
    As a last resort try removing pin 1 from inside the OBDII end of the EFILive OBDII cable. That pin is connected to the vehicle's low speed CAN network which may be interfering with the instrument cluster. FlashScan does not use pin 1. That pin was designed/reserved for an old Chrysler protocol that has never been implemented in FlashScan.
    You'll need to physically cut the pin as close to the back of the plug as possible to prevent it from contacting the low speed CAN socket in the vehicle's OBDII connector. Let me know if that fixes the problem. If it does then we'll need to keep hunting for the source of the problem with pin 1.
    My G8 goes crazy if I plug in my V2 with the car running. It flashes contact dealer and then goes away. If you plug in before starting the car it doesnt do it.
    Apr 2008
    will test and get back to u.
    Regards,
    Odd Boy
    Quote Originally Posted by minytrker View Post
    Interesting... it's as if the modules see that the canlan is already busy so they don't even try to talk on it.
    A canlan protocol analyzer would be a very handy tool.
    Junior Member brentg454's Avatar
    Sep 2006
    Just curious, is there a fix for this? My 2000 C5 loses the radio and IP, and resets the clock when plugging the V2 into the OBD-II connector. Doesn't matter if the key is on or off before I plug it in.
    Thanks!
    Brent
    2000 C5 FRC, some stuff.
    2006 TBSS, more stuff.
  1. Full flash only loses serial number
    By roughneck427 in forum Duramax LB7
    Last Post: July 16th, 2013, 12:23 PM
  2. DSP5 installed and ECM loses communication
    By dansdieselp in forum Duramax LB7
    Last Post: August 7th, 2012, 01:48 PM
  3. RR Loses VIN and CASE and OLM after losing power?
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: February 1st, 2011, 03:44 PM
  4. roadrunner loses comm. and locks up software
    By rubbersidedown in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 20th, 2007, 01:00 PM
