Results 1 to 2 of 2
Thread: 2011 gmc sierra 5.3 e38 superchargered which VVE table???
    Feb 2008
    Default 2011 gmc sierra 5.3 e38 supercharged which VVE table???
    I am having issues with a getting this truck to fire up and idle after doing a cam swap.
    what VVE table actually affects fueling as the engine returns to idle or after a rev in neutral?
    IMTV open? Closed?
    what determines whether to use the 2bar/3bar tables?
    Are you running MAF-less (SD), if so, are you getting an immediate MAF DTC...?
    What MAP sensor do you have (2-bar, 2.5-bar, 3-bar), did you set the MAP scaler/offset...?
    The 1-bar, 2-bar, 3-bar VVE tables occupy the same space, the coefficients you generate from the particular VVE table is what the ECM uses... so if you have a 2-bar MAP sensor and you edited the 2-bar VVE table, and generated coefficients from that, and are running a 2-bar MAP sensor with correct scaler/offset, then the ECM is using the coefficients generated from that.
    IMTV Open if none exists (actually, some people populate both tables IMTV Open and IMTV Closed with copy/paste).
  1. 2000 GMC Sierra w/5.3L
    By TurboRick in forum Gen III V8 Specific
    Last Post: December 18th, 2012, 01:10 PM
  2. turbo 4.8 GMC Sierra
    By noob in forum Gen III V8 Specific
    Last Post: September 19th, 2011, 12:39 PM
  3. 00" GMC Sierra 5.3L
    By ZL1Killa in forum Gen III V8 Specific
    Last Post: August 22nd, 2009, 12:42 PM
  4. Replies: 41
    Last Post: April 27th, 2009, 02:10 AM
  5. 2006 GMC Sierra 5.3L ???
    By chatcher in forum General
    Last Post: April 12th, 2006, 01:18 PM
