Results 1 to 5 of 5
Thread: A-40 os 25941751
    Jan 2015
    Default A-40 os 25941751
    Does anyone out there have OS 25941751? Or maybe a full flash of the 25836826 so i can change the OS. Thank you
    08 LMM CC Dually
    Canada
    Dec 2005
    You will need to seek a dealer and they will need to FULL FLASH/Reprogram the TCM with TIS, only a Cal Flash is available on the A40.
    www.mscservices.net
    Jan 2015
    OK thanks. I was thinking we still had the option to change the folder in v7.5 to make it full read/flash. Ross had posted a while back.
    Anyone with just the Cal? I want to see if that will work for me.
    08 LMM CC Dually
    Canada
    Quote Originally Posted by LMMPerrona View Post
    I got your PM. It was posted, but I could never get full read to work. I imagine that others duplicated my result.
    Custom Tuning Services
    Jan 2015
    thanks for the help guys.
    I tried it with techII and no luck. my neighbor has an a40 tcm so i asked if i can read it. I did a full read for like an hour. after the read it said invalid checksum. I ignored it and full flashed mine. it all worked... TCM is back running. Thanks to EFILive, Keep up the good work.
    08 LMM CC Dually
    Canada
Tags for this Thread
