![Quote](images/misc/quote_icon.png)
Originally Posted by
bronson1376
I never figured it out, played with tuning talked to many people and still no luck, it has seemed to get alittle better over time now but not fully, I have always had my battery not charging at initial startup come on for a sec then go away and now the other day finally it quit charging the full voltage, not sure if that was the problem all along, because I always went off the gauge on the dash not an actual volt meter. I have a new alternator to replace it with and I'll let ya know if it cures the problems. I have went thru all wiring, all grounds, used lab scope on Snapon scanner to monitor crank and camshaft position sensors, changed MAF sensor all with no luck, so hopefully this will fix the problem!
