Page 66 of 75 FirstFirst ... 16566465666768 ... LastLast
Results 651 to 660 of 741
Thread: Calc.VET: correcting MAF and calculating VE (in single log)
  1. #651
    May 2011
  2. #652
    May 2011
    i took the above maps created by the calc ve tutorial but i think i must have something wrong in the pids or the maps... can any of you view my created maps through my log i posted?
  3. #653
    Something is wrong with the values of the pid EXT.WO2LAM1, they should range from 0.5 to 1.5.
    Which wideband are you using (did you say LM-2)...? Something is wrong with it.
    Can you log it's 0-5V analog output to see if it correlates...?
  4. #654
    May 2011
    yes it is the lm-2. i am trying to trouble shoot that issue. do i need to be looking for a problem with the wideband controller itself or something incorrect with how i have my scan tool setup. sorry i feel so dumb on this. i am not understanding how i am getting wideband data on to the scan tool yet that one pid is showing what it is.
  5. #655
    May 2011
    My calc.vet setup on the scan tool, something is not right. And when I click on the calcpids in the beginning of this post an error comes up saying that calcpids is an invalid efilive file
  6. #656
    I just clicked on the calc_pids.txt link at the beginning of post #1 and it opened ok in Windows Notepad...
    when you click on it you want to save it to your PC (i.e. do not open in as an EFILive file).
  7. #657
    May 2011
    okay... duh its been a minute since ive been at it. it kept opening it with efi live...
  8. #658
    Jul 2015
    i need help i have went thru this post on calc ve and my question is i run sd mafless and i always disable ltft and stft and tune my ve i use a map that shows me the wideband afr rpm vs map kpa and then i go cell to cell and make adjustments i would love to use this method im just curious what script i need and pids to use i use a lm2 in serial . i also see auto ve is a option but the write up uses analog wideband im sure i could switch to analog but there has to be a way to do it in serial thanks in advanced im a rookie
  9. #659
    Quote Originally Posted by sweettl69 View Post
    Ok, you're running OLSD (no MAF, no LTFT, no STFT)...
    in that case you would do the Calc.MAFT procedure, concentrate on the VE correction part, and ignore the MAF calculation part...
    i.e. just correct the VE table, use the pid CALC.WO2BEN instead of CALC.SELBEN to correct the VE.
  10. #660
    May 2016
    I must be missing something. When I copy and paste the calc_pids-2.txt I cannot see the additional pids CALC.LTFT CALC.LTFTBEN CALC.VE_Table. can anyone enlighten me?
  1. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 06:26 PM
  2. OLFA table vs. Custom OS A0008 table
  3. Table Names vs Table Number
    By lplott in forum Custom Operating Systems
    Last Post: May 17th, 2006, 05:14 AM
  4. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
