Yes, compatible with .ctz, see posts #1 and #2.
As indicated in post #1, goto F5: BBX, and create one or more pidlists for your ECM/TCM.
What is your V8 software build version...?
What is your V2 firmware version...?
You can log with V2 only (Black Box Logging, BBL) so you don't have to bring your laptop with you in your vehicle.
With V2 you can also read from PCM and write to PCM without needing a laptop (you do a laptop to edit a tune).
