Results 1 to 8 of 8
Thread: Commdoore L76 (e38) and 4L80e (T42) issues
    Dec 2010
    Default Commdoore L76 (e38) and 4L80e (T42) issues
    Hi Guys,
    Have setup a vehicle with a E38 ecu and T42 trans ecu from a VZ Commodore L76/4L60e
    The vehicle is shifting gears and vehicle is very sluggish although im getting Lost comm codes between the ecu and tcm, Uxxx codes
    I have installed a T42 trans tune for a 4L80e originally 4L60E
    I have also modded the harness and wired it up as if it is a 4L80e to suit a T42, inc wiring the external ISS and swap pin in the Big round connector etc
    but I am not getting any engine or trans data from the ecu or tcm while using the efilive scanner, can read and write all ok. and also can watch live data with hptuners scanner, but have no vehicle speed....
    Do I need to run the 4L60E tune file and swap data?
    Anyone else had any similar issues?
    Cheers Mat
    Dec 2010
    upload of files from vehicle
    L76auto4l60estock.ctz
    Quote Originally Posted by mattyc View Post
    Ok, I'll take a look.
    Dec 2010
    Engine and box are not in a commodore anymore, and I still need to tune the engine, so if I need to change the operating system in either the Ecu or Tcm I can do that before I start tuning it.
    Your WOT upshift/downshift MPH parameters are upside down.
    TCC throttle release for 4th gear should also be 100% everywhere.
    Dec 2010
    thanks mate,
    also do I need to change the file as im getting lost communication codes between the pcm and tcm??
    are the tuning files im using compatable with each other?
    Aug 2010
    The 4L80 T42 calibration you are using is from a 2007 2500 Truck, and was posted on this Forum years ago. It has communication issues (i.e. it doesn't communicate) with most ECM operating systems.
    A 2008 or 2009 4L80 T42 calibration from a 2500 Van would likely work - I am not certain as you are using a Holden E38 OS (which I never use).
    Dec 2010
    Ah....
    Thanks for the info!!!!
    Now the big question is has anyone got a van file or know where I can locate one?
    Cheers mat
  1. T42 4L80E cal.
    By HOWQUICK in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 17th, 2014, 02:57 AM
  2. t42 4l80e tune
    By eacostad in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 10th, 2013, 01:06 PM
  3. 08 Sierra 4l80e t42 issues
    By 2007chevy5.3l in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 23rd, 2012, 06:54 AM
  4. 2000 4L80E with T42?
    By v8vegaman in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 21st, 2009, 03:27 AM
  5. L76 4L80e AFM
    By 4wheelin in forum E37, E38 & E67 PFI ECM's
    Last Post: November 24th, 2008, 11:04 AM
