Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 94
Thread: 2005 Tahoe ppv lq4 swap questions
  1. #21
    May 2011
    I think I got it now.
    I ALSO tHINK I NEED TO LOG MORE TABLES - when I copy over to the B0101 table its nasty looking dips and jumps in the graph - I think I will try again tomorrow and wait for some responses.
    Does 36 degrees outside affect what im doing or trying to do?
    99 ECSB 1500 6.0 lq9/243 2wd 3.42 in the works.
    Efans - CAI - Walbro 255lph - Eaton LSD
    BTR STAGE 3 truck cam - 60lb Inj - MP122HH
    FLT Level 5 - 3000 SC YANK
    Pacesetter LT's - ORY
    13.170 @ 103.33 Mph -
  2. #22
    Log for longer... use smoother progressive throttle, don't yank it open... use brakes to induce more load.
  3. #23
    Quote Originally Posted by Trxmxzx View Post
    You have 27 pid channels (which reduces the sampling rate from 10 frames/s to 5 frames/s).
    Is this from doing AutoVE or CALC.MAFT...?
  4. #24
    May 2011
    Yes I noticed that also I will change them to 22 channels to watch.
  5. #25
    May 2011
    alright I fixed the pid list.
    heres the new log
    going to do another drive, try to get more cells hit
    Let me know if im on the right track please.....ill be back in 20 min
  6. #26
    May 2011
    DRIVE LOG 3 - this road was bumpy it was hard to keep throttle steady - had corners with some stall outs
  7. #27
    Nov 2013
    Hey, in regards to log 2 I have some observations. At times it looks like your narrow bands diverge from each other. At frames 2108 you can plot and see they follow each other nicely, but then you see at 2198 and 2239 that they completely diverge, one says rich other says lean. I think low mV means low of stoich, and from there you can see that the WB02 agrees mostly with H02S11. frames 2510 to 2726 have good cyclic behavior around stoich and the WB agrees.
    What I don't see is your CALV.VET map or pids. It might be how I download and open your tune but I don't see that you have collected them. can you confirm that you are indeed making the map with the parameter names calc.vet, calc.ven and calc.cl?
  8. #28
    May 2011
    Yes I have the calc.maft pids selected right now. The second sticky down. Should I being different?
    At first I had calc.vet plus some autove pids plus others I accidentally saved as joe car pointed out.
    I must need to setup more maps to log if I need calc.ven and calc.cl I didn't see how to do that part
    Thanks for all the help!!! I'll be looking at the log tomorrow -
  9. #29
    Make sure your transient filter removes those WO2LAM1 excursions above 1.4 or 1.5.
    Post screenshots of you maps.
    With Calc.MAFT you are correcting (paste-multiplying) VE table, and calculating a new MAF (pasting)... ignore the MAF part for now, concentrate on the VE table.
    In the log, look at WO2LAM1 to see if it makes sense... CALC.CL tells you whether LTFT's or WO2BEN are to be used for correction.
  10. #30
    May 2011
    this is my ve table before I paste with multiply - something just doesn't seem right at all
  1. lq4 and 411 pcm swap in 98 suburban
    By Eric in forum Gen III V8 Specific
    Last Post: October 10th, 2015, 04:21 PM
  2. LQ4 swap lost communication, spark, and fuel.
    By C450 in forum Gen III V8 Specific
    Last Post: April 7th, 2015, 02:40 PM
  3. LQ4 hotcam Third Gen Swap
    By jbettcher in forum Gen III V8 Specific
    Last Post: May 19th, 2013, 06:49 AM
  4. 2005 Silverado New Built LQ4 No start
    By 2005 silverado in forum Gen III V8 Specific
    Last Post: November 7th, 2012, 05:05 PM
  5. Help with tuning my cammed 6.0L LQ4 jet boat swap please!
    By Wasted Income in forum Gen III V8 Specific
    Last Post: June 15th, 2010, 08:24 AM
