Results 1 to 9 of 9
Thread: 2 bricked pcm's please help
    Mar 2008
    Default 2 bricked pcm's please help
    I made transmission setting changes to my tune and loaded it and it bricked the PCM. It ran all the way through and said flash completed successfully. When I hit OK my fuel pump went crazy and it wouldn't reconnect. I tried reflashing and full recovery and it just says PCM not detected. I pulled the PCM out of another vehicle and loaded the old calibration in it and everything was good. I then tried to load the calibration with the updated trans setting and it bricked that one too. I can't afford to buy new pcm's and licenses right now so I'm kind of screwed. What the hell is going on?
    What PCM/ECM and post the tune files please. Once we have that info I'd be happy to spot check the tune and then EFILive can take a look.
    Aug 2004
    My guess is you are messing with speedometer settings that are to wrong.
    What changes did you make...?
    Mar 2008
    Quote Originally Posted by wait4me View Post
    That is possible. I was changing to a 28" tire for the track so I was adjusting tire size and shift points. If that's the case, is it recoverable? I can post up the file later.
    Aug 2004
    send them to me and I can repair them. The chip needs pulled and redone
    Mar 2008
    How much to repair both pcm's? I tried to pm you and called.
    Aug 2004
    you called after the phones where turned off for the night probably. 7pm,
    Call during biz hours and I can help you out. Thanks
    Aug 2004
    Returned your call. Thanks
  1. Replies: 6
    Last Post: September 18th, 2014, 10:38 AM
  2. Bricked The V2??
    By RobsDmax in forum FlashScan V2
    Last Post: July 24th, 2013, 09:53 AM
  3. Bricked H3... almost
    By SwedeBurb in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: May 13th, 2012, 10:33 AM
  4. Bricked my PCM- What to do?
    By 67RsCamaroVette in forum Gen III V8 Specific
    Last Post: October 23rd, 2011, 08:02 PM
  5. PCM bricked while
    By Chuck L. in forum Gen III V8 Specific
    Last Post: June 29th, 2011, 08:46 AM
