I will need to remove 3 PID's if I add those. I had to remove 2 to add the PID's for actual and commanded VVT. I can remove those 2, and will look and see which other I can likely remove. I have an email out to my first tuner to see if he still has my unmodified 5.3 tune.
That tune in post #1 was my local tuners final attempt at getting this truck running correctly.
The tune in post #9 was a national tuners last tune back to me, and they have not made any changes to it in over 2 weeks and the last emails back have not asked for anything further and are stating clogged injectors is the problem. I anticipate being able to send out my injectors soon to be ultrasonically cleaned, but have no spare injectors of the same size. I do have the ones from my 5.3 which were also flex fuel injectors so my hope is that they turned out to be the same part number.
I will hopefully get this new log taken today, I appreciate the help!
Josh
