Results 1 to 4 of 4
Thread: VVE Sense Check - This looks Wrong!
    Senior Member Behold's Avatar
    Apr 2010
    Default VVE Sense Check - This looks Wrong!
    So helping a friend and we came across this 2 bar VVE table.
    Is it just me or is this just plain wrong. I'm taking it the only way this could work is if PE modifiers are fixing the fueling over about 80kpa???
    Thanks Antony
    Holden Commodore GTS - LS1 5.7
    12 rib Crank Driven Vortech V2 Centri Charger (Intercooled) 9 PSI.
    LS6 Intake
    LS6 Heads
    YT 1.7 Roller Rockers
    BTR Dual Spring with Ti retainers
    BTR Hardend 7.400 Push rods
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    PCM LS1B with 512KB Running COS5 v01290005
    Hey Antony,
    The 1-bar VVE table is correct... the 2-bar and 3-bar (whichever one will be used) need to be fixed up and corrected
    ( and you will have to redefine the VVE zone boundaries ).
    Quote Originally Posted by Behold View Post
    Yes it is horrible, but Holden never needed to account for 2bar so it does taper off pretty bad beyond 100kPa.
    Apr 2010
    The car is meant to be tuned for 9 psi.....
    The map sensor was incorrectly scaled to around 1.1 bar and kind of runs although a bit rich and lean at times.
    So in theory if I was to take the 1 bar and stretch it in to the 2bar. (I know what kpa is really against the incorrect scale.) it would be fine once the map sensor reads right.
    I take it there will be some adder tables a bit messed up. What else? I'm doubting all the tables are scaled down. Timing maybe.
    Thanks all.
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
  1. 05 Silverado 5.3 Ol/CL afrs dont make sense
    By camaro10 in forum Gen III V8 Specific
    Last Post: September 1st, 2015, 04:52 PM
  2. EFILive's explanations do not make sense
    By Black6spdZ in forum Cummins 5.9L
    Last Post: June 18th, 2014, 01:36 PM
  3. LMM B1059-Making sense of it
    Last Post: November 2nd, 2009, 02:41 PM
  4. Out of range calibration not making sense
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: July 8th, 2006, 01:18 PM
  5. Does this make sense?
    By turboberserker in forum Custom Operating Systems
    Last Post: February 2nd, 2006, 05:01 PM
