Results 11 to 20 of 40
Thread: calculated pid not valid for NGK/NTK Air-Fuel Ratio Monitor
    Quote Originally Posted by Trackman View Post
    Thank you. That got it working. Unfortunately my formula must be wrong. My afr is reading 4 points to low. NTK suggest {(vout-0.5)x2.75}+9
    I have:
    *CLC-00-003
    AFR 9.0 20.00 .1 "{EXT.AD1}-0.5*2.75+9"
    When I looked more closely at your formula (and compared it to the NTK user manual pdf) I see it is incorrect...
    it should have parenthesis around the subtraction term, like this:
    "({EXT.AD1}-0.5)*2.75+9"
    Jun 2014
    Thumbs up
    Thank you joecar.
    The formula works great.
    For anyone using the new NTK air /fuel monitor (model 96604) the above formula is what you need!
    Jun 2014
    It's been a while! I am looking for a little trouble shooting help again. I am running a new engine set up now and its been a long time since I have datalogged. I have forgotten most of what I had learned. The issue I am having is getting my afr monitor to read correctly on a log. It used to work perfect. Is there a specific 0-5v input I should be using? I notice my pid (the wideband described in this thread) is under the system Fuel. Should it be under the system WO2-Analog?
    The system it is under is a user definable string.
    Post your calc_pids.txt file from the folder C:\users\xxxx\documents\EFILive\V7.5\User Configuration.
    Jun 2014
    Here it is.
    Ok, it is missing some stuff...
    I added in what I thought was missing, see attached (assumes E67 ECM).
    Which ECM does you have...?
    Edit: correction;
    and corrected again.
    Jun 2014
    I have the E67
    Ok, the pids CALC.NTK_AFX and CALC.BEN_NTK_AFX should work for E67.
  9. #19
    Jun 2014
    I replaced pid txt with your version. I get this when I try to add the pid now. I assume I need to delete the bottom 2 somehow.
Name:	afr not valid.jpg
  10. #20
    Did you select the pid EXT.AD1...?
    Did you select the pid CALC.NTK_AFX...?
    This is what I see:
Name:	2016-04-30 21_10_28-More information.png
  1. Air/Fuel Ratio Adjustment
    By kylelavergne in forum Gen III V8 Specific
    Last Post: December 26th, 2013, 04:22 PM
  2. Air Fuel Ratio or Timing for Peak Power
    Last Post: September 23rd, 2009, 04:42 AM
  3. Air-Fuel Ratio Monitors
    By Sid447 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 24th, 2009, 09:45 PM
  4. AFR Command Air Fuel Ratio
    By james01ss in forum Gen III V8 Specific
    Last Post: October 6th, 2008, 01:33 PM
  5. Air Fuel Ratio
    By batesyellow01 in forum Petrol / Gas
    Last Post: March 15th, 2007, 03:25 AM
