Page 34 of 37 FirstFirst ... 243233343536 ... LastLast
Results 331 to 340 of 364
Thread: Custom OS#5
  1. #331
    whats the chances of being able to edit or allow support for up to 25 degrees of timing to be removed in the A0010 table? with the use of ethanol now, my normal timing map is is above 20 degrees under boost and i want to allow for a whole lot of timing removal if it looses a boost reference to the wastegates etc.
    is it just an efilive limit for the table or ecu/tune limit?
  2. #332
    Updated COS5.txt notes.
    Bump to the end of the thread, and minor edit.
  3. #333
    Jul 2003
    Anyone know about Black02ss? 10 years since his last post.
  4. #334
    Pretty sure he left the whole scene a long time ago, I think he sold his car and moved on.
  5. #335
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    That is too bad he left. I am not on very often either but I am still here.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
  6. #336
    Yeah, too bad.
  7. #337
    May 2007
    Yeah, too bad.
    I have recently started looking back into the tps ve table. when I open the map for it in scan tool, it is missing a pid. what all pids are needed to log tps ve?
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
  8. #338
    Which pid are you missing...?
  9. #339
    May 2007
    Honestly not sure. I have Volumetric Efficiency selected , what else is needed for that and how do I tell what is missing for each map?
    2000 NBM trans am.
  10. #340
    Oct 2006
    Quote Originally Posted by Aint Skeered View Post
    T.P.S VE requires the Throttle Position and RPM pids to be selected as these are what is referenced on the Axis of the table. Also the VE table look up value pid is required to initially populate the table.
    From there you can start using BEN values to dial the table in once activated.
    The Tremor at AIR
  1. Two PCM's with same Custom OS HELP
    By superspeed in forum Gen III V8 Specific
    Last Post: February 1st, 2009, 02:45 PM
  2. custom OS with efi v1
    By dsmlights in forum Custom Operating Systems
    Last Post: December 5th, 2007, 07:28 PM
  3. Why LM-1 Custom PID???????
    By 2002_z28_six_speed in forum General
    Last Post: June 4th, 2007, 12:52 AM
  4. Custom Os???
    By FFP in forum Custom Operating Systems
    Last Post: December 7th, 2006, 01:11 PM
