I went through the Calc.MAFT setup and have been using it to tune for my cam. Overall it's worked fairly well to get a general tune, but it seems like my commanded AFR is either off, or EFILive thinks that the actual AFR that my wideband is off (though the handheld is showing the proper value). Essentially, I will have areas, say low speed cruising, where the AFR is 13.5-14.0, and one spot right at 2000 RPMS where it goes super lean, 16.5-16.9. I will let Calc.MAFT do the logging and all, and the end result is 1.0, basically it thinks that the AFR reading is spot on.
I can fine tune it, but trying to do this on a cell by cell basis in the B0101 is tedious. Anything I might be missing? Keep in mind I literally have just started learning, so this is a step by step process for me.
Thanks in advance!
