Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 2009 Silvy with 4L80E swap ... can someone look over the TCM file?
    May 2014
    Default 2009 Silvy with 4L80E swap ... can someone look over the TCM file?
    Just need to make sure everything in there is good as it is. The only changes I've made are updating the gear ratios from 4L60E to 4L80E values and adjusting speedo tire revs/mile ... someone may have been in there in the past, just not sure if they did anything else. I can't seem to find any files to compare and the repository seems to be offline.
    Thanks in advance!
    I'm look thru you file, I'll post back later today.
    Did you repin the harness...?
    May 2014
    Using a Frost adapter harness with the external PDNDL switch harness pinned in. Previous pwner only set it up with the neutral safety part of it jumped to stock harness, nothing worked through BMC and no-lockup. Now lock-up etc. and all the BCM features work after I added the PRNDL option. The early Frost harness didn't have the PRNDL connector on it since that was part of the vehicle harness and not internal to trans like in 2009
    The Frost harness is for driving a 4L80E from a 4L80E segment, correct...?
    ( i.e. not the other harness which drives a 4L80E from a 4L60E segment )
    May 2014
    Well, from talking to him, it didn't need anything but the harness and no segment swap was needed. How would I know that a segment swap is needed? Everything seems to work and shift correctly; although a little too firm.
    Is there a way to test two different files with/without?
    May 2014
    This is what's used ... http://www.tunedbyfrost.com/products_dev1.htm
    with the following leg pinned in...
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    Joe - this is the same truck I have been working on - he is working on the transmission while I try to figure out the tune. It is controlled by a T42 controller - when you do a 4L80E swap on these, you don't swap segments do you? not sure how you could...
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
    May 2014
    So the only thing glaring I saw against another tune someone else uploaded here is the 1st gear wot setting from speed only (what was) to speed and rpm (what is now) ... it may be my imagination but with the gear ratios and this change that I just reflashed, truck behaves a bit better around town
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Since this is a T42 (can't do segment swap) from a 4L60E, you have to use Frost's cable (which uses a relay to invert the 2-3 Shift signal and uses the TCC On/Off signal to drive the TCC).
    I'm still going thru your tune.
    What rear axle gear ratio do you have...?
    What tire size...?
  1. Need blackbox 4L80E tune for my 4L80E segment swap
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 10th, 2013, 10:57 AM
  2. 07.5-08 tcm in a 2009-10 LMM
    By IdahoRob in forum Allison 5 & 6 Speed
    Last Post: February 4th, 2011, 10:33 AM
  3. 2009 colorado 5.3 want to install a 4l80e
    By MECHAN12 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 21st, 2010, 11:52 AM
  4. anyone have a 2009+ A50 TCM file??
    By DURAtotheMAX in forum Allison 5 & 6 Speed
    Last Post: August 20th, 2010, 12:51 PM
  5. 2009 duramax tcm tuning
    By dgdyno in forum Allison 5 & 6 Speed
    Last Post: June 1st, 2010, 03:56 AM
