Page 8 of 10 FirstFirst ... 678910 LastLast
Results 71 to 80 of 94
Thread: 2005 Tahoe ppv lq4 swap questions
  1. #71
    May 2011
    We are back at it- idle pressure
    99 ECSB 1500 6.0 lq9/243 2wd 3.42 in the works.
    Efans - CAI - Walbro 255lph - Eaton LSD
    BTR STAGE 3 truck cam - 60lb Inj - MP122HH
    FLT Level 5 - 3000 SC YANK
    Pacesetter LT's - ORY
    13.170 @ 103.33 Mph -
  2. #72
    May 2011
    He took it for a drive last night no pressure drops, he's doing it again tonight to see if anything happens
    if we don't get any results of pressure drops whats our next move?
  3. #73
    Ok, rail pressure is good (I take it you have an un-referenced FPR, I forgot already)...?
    Next step: are all the injector tables correct...?
  4. #74
    May 2011
    The fuel pressure we never checked at first- then there was a lean spot while cruising at around 2000rpms and 20% TPS both O2 sensors showed extreme lean and WB showed 5.4 lambda which I didn't think it could go that high. I posted a pic of the graphs in previous page. Jet pointed it out. You also recommended to double check. (Just bringing you back up to speed seeing it's been 3-4 weeks)
    It's the stock injectors for the 5.3 flex fuel that came on the truck from factory. We didn't change anything.
  5. #75
    Ok can you post a new log, or what Jetmech wants you to do...
  6. #76
    May 2011
    Ok no pressure drops in fuel
    Here's one log its kind of lengthy
  7. #77
    Quote Originally Posted by Trxmxzx View Post
    That is pretty good...
    there are 2 almost-WOT areas where WO2BEN goes above 1.05, see if you can fix this in MAF and/or VE (manually by hand).
    LTFT's are close (not far from zero)... on closed throttle they wander a little but that's ok.
  8. #78
    May 2011
    Are those lean spots where he hit his rev limiter? Due to stall converter? Fuel shut off
    I need to adjust it in the settings and couldn't confirm the correct method- do I lower the desired rpm threshold about 1000rpm? For inbetween shifts?
  9. #79
    Just increase the MAF a little in those spots, and try to blend the surroundings, then take a log and see if it does the same.
  10. #80
    May 2011
    MAF is still shut off friend- or are you saying add more air in the MAF so I can go back to using it and take a log?!?
  1. lq4 and 411 pcm swap in 98 suburban
    By Eric in forum Gen III V8 Specific
    Last Post: October 10th, 2015, 04:21 PM
  2. LQ4 swap lost communication, spark, and fuel.
    By C450 in forum Gen III V8 Specific
    Last Post: April 7th, 2015, 02:40 PM
  3. LQ4 hotcam Third Gen Swap
    By jbettcher in forum Gen III V8 Specific
    Last Post: May 19th, 2013, 06:49 AM
  4. 2005 Silverado New Built LQ4 No start
    By 2005 silverado in forum Gen III V8 Specific
    Last Post: November 7th, 2012, 05:05 PM
  5. Help with tuning my cammed 6.0L LQ4 jet boat swap please!
    By Wasted Income in forum Gen III V8 Specific
    Last Post: June 15th, 2010, 08:24 AM
