Post your current log file and the tune file that produced it, I'll look at them later tonite.
dans curent scrap_0000.ctzLog_0008.efidans curent scrap_0000.ctz Log_0008.efi
current tune current log
This poor truck went thru some paces today.....I went back and had a peek at original tune i see what you are talking about with B0101 I'm not sure how or when it got changed but i went back to original and made new log ......some of those boxes are very hard to hit especially with ETC in a bouncy old truck
Log_0009.efi __ dans curent scrap_0004.ctz
Several things are going wrong...
GM.DYNAIRTMP_DMA has the wrong values, this causes CALC.VET to be wrong... you will have to use the B4901 variant of Calc.VET (i.e. not log GM.DYNAIRTMP_DMA anymore, we can't rely on it), in the Calc.VET thread post #1 see III. Appendix point # 6... so we'll have to then start from scratch.
MAP peaks at 87 kPa... what elevation is your physical location...?
In the log I see WOT but RPM does not increase, what is going on here...?
i do not understand how to create or use calc. pids it shows up in pid list but is not valid i read the how to create pids tutorial several times but cant make sense of it ill play around with it some more......i'm at 3500 ft I don't know why throttle is doing that ill have to dig into that i shifted up on a hill to try and get lower rpm/higher kpa cells and it just didn't do anything
this old truck is so bouncy and jerky throttle control is very difficult those homemade dyno guys on youtube got me thinking lol
Log_0010.efi dans curent scrap_0004.ctz Think getting closer
