Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
Thread: turbo Silverado lean spikes/stumble
  1. #31
    lol, I'm officially an alien.
  2. #32
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    Joe - what would make my laptop keep going to "not responding" while trying to log? It freezes up and I have to restart it. He brought the truck over and I tried to use my laptop to log - never had this problem before... any ideas?
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
  3. #33
    What laptop is it...?
    What V7 software build version...?
    Is this with FlashScan V2...?
  4. #34
    Jun 2005
    Toshiba Satelite/1.40GHz/4GB RAM/Windows 10
    V7.5.7 (build 299)
    Yes, FlashScan V2
    GM EFI Tuner
  5. #35
    Jun 2005
    So, with a scaled tune, we got a good pull on it with no MAF, and the spikes aren't there. It was a bit rich, but pulled great even through a shift.
    We hooked up the MAF, and the spikes came back - missing and stumbling like before we scaled the tune. What gives? Can we not run the MAF with this much boost?
    GM EFI Tuner
  6. #36
    I think it has to do with C0803, C0804, they have a maximum range of upto 512 g/s... but you scaled, so I don't know...
  7. #37
    Jun 2005
    I would think if it was to do with those, it would do it in SD, but it doesn't. I'm searching through other posts, but I'm not finding anything so far. I'm stumped. We may just have to run SD and he can plug in the signal wire when he has to go to emissions (and stay out of the boost)... I'll keep trying to figure it out, but this is getting extremely frustrating...
    GM EFI Tuner
  8. #38
    Jun 2005
    One other thing I forgot to mention - I kept knocking down the VE table in huge amounts trying to lean it out to commanded, so I got to thinking... the PWM fuel pump maintains pressure much like a regulated setup, but the IFR table is sloped. I changed it to a flat table and the top end of the VE came in much closer. It seems to be working. If only I could figure out this MAF issue... Here is the latest tune and log with no MAF.
    GM EFI Tuner
  9. #39
    Quote Originally Posted by BLK02WS6 View Post
    Ok, so is that how the PWM fuel pump behaves, it increases rail pressure as MAP increases... if so then a flat IFR makes sense.
  10. #40
    May 2014
    Yeah the tables have low/normal/high(PE) kpa settings and it's been good at keeping up with the set pressures so far! Still stock pump but injectors don't seem to be maxing out yet and if anything, the wideband readings show rich!
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  1. Random lean spikes after letting off throttle
    By ferocity02 in forum Gen III V8 Specific
    Last Post: April 2nd, 2014, 05:22 AM
  2. Lean Cruise for a 09 Silverado
    By PACougar in forum Gen III V8 Specific
    Last Post: June 3rd, 2011, 08:19 AM
  3. 04 Silverado turbo 6.0 help.
    By Janke in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: March 1st, 2011, 10:56 AM
  4. Lean spikes commanded vs actual AFR
    By billyjo in forum Custom Operating Systems
    Last Post: January 24th, 2008, 05:58 PM
  5. Lean spikes
    Last Post: June 2nd, 2007, 04:20 PM
